(Topic ID: 208341)
Alice Cooper's Nightmare Castle Club: Enter at own risk!
By Sarge
  • 6,826 posts
  • 359 Pinsiders participating
  • Latest reply 5 hours ago by Spacemanratso09
  • Topic is favorited by 141 Pinsiders
11 key posts have been marked in this topic, showing the first 10 items. (Show topic index)
There are 6,826 posts in this topic. You are on page 136 of 137.
#6751 34 days ago
Quoted from rockrand:
Have you tried reflowing the crypt optos?
Yes, tried that + reseating cables. But now it was a few days since trying. So would be grateful for pics on right ramp opto and crypt optos connections on the opto board.
#6752 34 days ago
Quoted from XatchieS:
Swap that optos switch board with another switch board the same. From memory there is another switch board right above the one that those optos run to.
Then check that the problem remains with those optos (and hasn’t moved to other switches with the original switch board)
I have seen one of those switch boards go flaky. Easy to check (takes a couple of minutes to swap around boards) and if the board is the problem, saves you hours of chasing faults.
rd
#6753 33 days ago
Quoted from rotordave:
rd
Thanks for the tip, tried it. Problem stays the same. Anyone know what opto article/serial number they use?
Tried 14231 but those dont work at all instead it seems.
Would love if some1 could take a picture on optobord for crypt and solderjoint(cable colour) for crypt opto.
#6754 33 days ago
These ones. One is a sender, one is a receiver.
https://www.pinballlife.com/williamsbally-infared-led-opto-assembly-set.html
You could always swap a set from somewhere else and see how you go.
rd
#6755 33 days ago
rd
Will try!
Working now! was bad optos or dirty optos , now im just trying to figure out why everyone else magnets seem to fling balls from the magnetic ball save and ours dont.
Tried both with "low magnetic" balls and shiny ones.
Also installed double plastic magnet protectors.
Tried all patterns and turning on off magnet resistor.
Any ideas?
#6756 32 days ago
I have an odd issue that has popped up recently. Randomly, throughout games my left scoop will make the "I'm about to shoot out the ball" sound and lightshow and fire the coil. Half of the time it will even eject a second ball out of the ball trough which often leads to funky code problems - sometimes doing so before hitting a flipper or plunging a ball. I've checked the stuck switch screen, as well as, monitored the switch test screen for anomalies - but nothing has come up in either one. I've made sure all connections were secure, reflowed solder joints on the scoop optos, and replaced the scoop optos.
Any ideas?
Also, does anyone know which Special setting awards an EB? It doesn't seem like any of those options work properly.
#6757 32 days ago
Quoted from GuiitarMan:
Any ideas?
Mine did that over the weekend too. Haven't had a chance to look at it yet but will start with a scoop opto clean.
#6758 32 days ago
Balls make no difference.
“Low magnetic” balls are what you want to use in games with magnets - because they are less likely to become magnetic. If they do become magnetic, then they will stick together in the ball trough (ie not roll down properly) and the game will get very confused. Not good.
Also note that all balls can become magnetic, even just by clinking together in shipping. Sometimes shit just happens.
With your magnet flinging - you know there are 4 (?) different magnet patterns in the menu?
From memory - original, pattern 1, 2 and 3.
So access your menu - see what pattern your machine is on, and try the next one for a few games. See what happens. Then try the next one. Etc etc.
Pattern 3 works best in my game, which still has the original big gold magnet resistor fitted (later games don’t have this fitted)
rd
#6759 31 days ago
Will try!
Any ideas?
Remove the resistor:
#6760 31 days ago
Any ideas?
After further investigation, the issue with the left scoop seems to only be happening after the game has been running for 10-15 minutes. I left the switch screen on and the LEFTSCOOP - 60 - (I) is what shows as being randomly triggering once. About 15 minutes later it starts going crazy with triggering TROUGHJAM - 51 - (A) and TROUGHJAM - 51 - (I) over and over and over again nonstop. Is this an opto or a subway switch?
#6761 31 days ago
The switches at the end of the ball trough?
rd
#6762 29 days ago
Quoted from dnapac:
To those with the topper. Mine stopped working. Blew the fuse. Replaced it and it works again…accept, Mr brain seems to move less (code thing? Have the latest code) and the dials don’t move. Anyone opened it and know the correct connection pins…I may have accidentally changed a connection. If nobody knows, that’s cool…I’ll hit up AJ at spooky or maybe that servo went bad.
I had to change the dial servo right atvzhe beginning, running now more than 1 year without any problems. Here some pictures, hope it will help you on Halloween
06451B74-72E7-4CE7-9869-8D5183C5C905 (resized).jpeg422FB8A8-F43B-405F-88A1-AC51AF7D0A37 (resized).jpegD484FCAB-8659-4606-B54D-7ACFCA20ED7D (resized).jpeg
#6763 29 days ago
Quoted from the_one:
I had to change the dial servo right atvzhe beginning, running now more than 1 year without any problems. Here some pictures, hope it will help you on Halloween [quoted image][quoted image][quoted image]
Thank you! Those are great. I had just replaced the fuse, but my brain stopped moving again and the dials haven’t moved in awhile. Time to replace both servos. Thanks for the pic of the wire pin connections!
#6764 23 days ago
Is spooky still working on new code for Alice, or are they done? I see some updates for Halloween/Ultraman coming and was hoping for an Alice update too.
#6765 22 days ago
Quoted from gibsonrd:
I'd guess only Spooky folks would know - SpookyLuke SpookyCharlie .
#6766 22 days ago
I would not expect new code anytime soon. They released one in March and they have their hands full with Halloween and Ultraman..
#6767 22 days ago
Is spooky still working on new code for Alice, or are they done? ...
#6768 17 days ago
does anyone have the original instructions for the apron cards? not found on the spooky website
#6769 15 days ago
Hello.
I have a little problem on my alice.
when unlocking Frankestein mode, the 2 balls go up with the character but the right ball remains stuck on the ramp. It is as if the Frankestein figure does not rise high enough.
I don't see how to adjust the height, in the menu or mechanically. It's really not accessible without disassembling everything.
Has this problem ever happened to someone? do you have any idea how to fix it?
Thanks in advance.
#6770 15 days ago
Quoted from pinballM:
Yes they emailed them to me when I asked about them.
My machines also didn't come with them installed (seems late builds did have cards).
Pm me your emailadres (or email spooky yourself to ask them).
#6771 15 days ago
Quoted from pinker:
Hello.
Thanks in advance.
In the settings you can adjust the frankenstein servo, there you set how high and low it can go.
#6772 15 days ago
YES! the problem is solved . Thanks for your help .
#6773 15 days ago
Quoted from aeneas:
Thank you for this, I didnt know I could adjust Frank's height.
#6774 13 days ago
Wondering if anyone here was looking to sell their Alice
Buyer with cash in hand
Have one I’m getting in 2 weeks but my brother wants one as well he doesn’t do the internet pinball forums
#6775 13 days ago
Quoted from Spacemanratso09:
Anything can be had for the right price
#6776 7 days ago
Finally got around to installing Ron's (Cento's) wall decal mod.
Promised (years ago? ) I'd post a pic when that happens. Sorry for the glass on with flash.
#6777 5 days ago
Have a line on a Alice
It’s mint like right out of the box very low play
This game is number one for us right now
It’s priced in the high 8s
Is this fair value?
Not trolling I want a one owner low play copy just never thought it would be that much
#6778 5 days ago
It’s price is in the high 8s
Is this fair value?
#6779 5 days ago
It’s prices in the high 8s
Is this fair value?
Here's a cheaper one but second owner and no shipping. Not many made and it's a great game, some collectors specifically seek out music or horror pins and this has both. Looks like last three or four sold in the 8k range or higher.
https://pinside.com/pinball/forum/topic/for-sale-alice-cooper-s-nightmare-castle-68
#6780 5 days ago
Quoted from manadams:
Thanks man I did actually see this one
I’m willing to pay for the right game
It’s just a lot dont want to chase
I appreciate the response
#6781 5 days ago
Is this fair value?
High 8s? I'm not shocked. This was one of the last games I thought was still selling far too low.
Fair value or not depends on the buyer. IMO, even if you pay a few hundred over, you're not going to lose value on it. See if you can talk them down, start at 8500 maybe. If it has lots of add-ons and pinstadiums or whatever, the seller may not budge and I can't blame them.
#6782 5 days ago
Is this fair value?
I think it will be hard to get that price back. Just make sure you really love it and it’s gonna stay for a long time. If that’s the case, go for it.
#6783 5 days ago
Quoted from chuckwurt:
The last two ACNCs sold for 10k and 9.5k. Granted the 10k had butter cab and a topper, and the 9.5k had tons of mods, but they are going up in value over time, not down. The one in Texas going for 7.5 is ridiculously low imo. That'll be the last ACNC that sells for under 8k for quite some time. It's a new ad but I'm shocked someone didn't snag it already.
We don't know the specs or add-ons of the one that Spaceman is talking about, but 8-9 is the min value of this game these days. I think he'll be fine to negotiate a deal.
#6784 5 days ago
Well so be it. Glad I’m not in the market for a Alice. Whoa baby.
#6785 5 days ago
Is this fair value?
8-8.5 on a factory ACNC with a couple options atleast i’d say.
9 if it has “glass” maybe some some of the Medisinyl mods
Exceptionally interesting game…has a very unique presence and immersive creepiness to it.
Get it, then do the rgb under cabinet and back box lighting mod….incredible
#6786 5 days ago
Thanks for all the response
He’s come down 200 for me still mid 8s
He has the type of game I want which is as close to new as possible
I plan on keeping it obviously and actually have sold a couple a couple games recently for a nice profit
Wanted to use that profit to get Alice
I’m going to buy it even if I’m paying a premium
I can’t believe I slept on this game for this long I just never seen one in person
Im pumped I appreciate the feedback can’t always worry about a couple hundred bucks here or there in this hobby on every game
#6787 5 days ago
Congrats on your game!
#6788 5 days ago
Quoted from tbutler6:
Thank you to say we are excited is a understatement
#6789 5 days ago
Mine stored from purchase (may2021) cuz lacking Space
#6790 5 days ago
Congrats!
I think it's a fantastic game myself. Pinstadiums are amazing on it, especially with the shaker motor, but the price of those things suck now.
#6791 5 days ago
Get it, then do the rgb under cabinet and back box lighting mod….incredible[quoted image]
#6792 4 days ago
I also confirm that the pinstadiums are really necessary on ACNC,
they should have integrated them in the pinball machine during the conception.
it is really incredible when you have to shoot the jackpot
what a great pinball . ACNC is the new Medieval Madness
#6793 4 days ago
it is really incredible when you have to shoot the jackpot ...
I recommend them as well for ACNC.
#6794 4 days ago
Quoted from ThePinballCo-op:
Absolutely correct. And compare to the prices people going to ask for recent STERN toppers, the Alice topper seems to we worth now as well 1.5k at least. I have seen Elvira topper getting sold at 2.2k USD here in Germany … that‘s really ridiculous
#6795 3 days ago
Not in this market and not moving forward into the future. Alice will catch up to the market and then some
#6796 3 days ago
Just FYI. My Alice was really acting weird. Lights that would shut off, modes that would sound but not match the graphics, shots that wouldn’t register, etc. I reinstalled the code and all is good. Pins are more and more a computer…so sometimes a clean slate is needed.
13
#6797 3 days ago
That’s was a long drive through the night
Alice in the house!
We love this game its so sick man
This is just what I was looking for at that price,today,was as close to new as possible
Thanks for feedback on my purchase again very happy I feel like I got lucky someone let it go to begin with
Happy thanksgiving ☠️
70EB2AF2-848E-4AAF-9224-1DB4BEBB5E2E (resized).jpegE7A00213-56F1-4043-AD08-2FF90F9C4F11 (resized).jpeg
#6798 3 days ago
Alice in the house!
Welcome to the club!
#6799 2 days ago
You'll want a rob zombie now. I reckon it's a better machine. 7 ball multi and all.
#6800 2 days ago
Hadn’t played in a while because I’ve been busy as hell with work.
Got into a game today where I defeated the pit creature and another where I defeated the werewolf (which is good for me).
Man does it feel good when you defeat a monster.
