Hello all, I am helping my buddy HopBeard work on his recently acquired ACNC and troubleshooting various problems his machine is having that seem to be consistent with this game historically and faulty switches. His is on the newest code version.
The game is losing track of balls at various points, sometimes all balls in trough isn't registering and other times the locked balls aren't recognized and the game then goes to ball check after the drain and gives some bonus balls while disrupting the game flow. He has recently replaced the balls with high carbon balls, and that didn't solve the issues. He also reached out to Spooky and received a couple extra switches and a new amp for the speakers which were shorting out / feeding back through the sub channel.
We have seen that the game seems to work OK for a few games and once things start failing then they continue to get worse and the game becomes unplayable, and rebooting at that point doesn't solve the issues.
specifically we're going to try to adjust / reflow / replace:
right frank lock switch(es)
crypt switch(es)
trough switches
My questions:
Are we missing anything obvious, for others who have worked on these issues?
Any particular recommended sequence for working through these?
Can the crypt switches be adjusted or worked on without removing the upper playfield?
Thanks in advance.....
