Hi all, I've got an Aladdin's Castle that I'm slowly getting up to snuff. I've got an issue with the 10's place scoring. It seems to be stuck on at the very first 10 point button/trigger press. Behavior is...
1. On turn on or game reset no coil buzz
2. At first ball when it rolls over the 10 point buttons at top (or when I manually press any 10 point trigger) the 10 point coil in the head locks on but the score reels (for either player) do not update.
3. Inside the cabinet the ball coil also locks on at this time, this is where I start to hear a minor coil buzz.
4. If I have the chimes plugged in (currently not) the 10 point chime coil makes a loud buzzing, i.e. stuck on.
5. Game plays normally near as I can tell besides not scoring any 10's.
6. The match counter/display works fine.
7. Reseated, filed, cleaned, and de-oxit'd all the j connector contacts.
8. The 10's worked IIRC a few days ago before I tore everything apart and cleaned contacts etc. Undoubtedly I geeked something but all the switches that I checked look like they work as they should.
I do have schematics but I'm having trouble reading them as the parts placement in relation to the schematic is not clear to me. Any guidance from the more experienced folks would be appreciated, thanks!
