Quoted from PinballManiac40:You mean the slot machine does not shoot out the ball even though the switch works?
I would still bend that switch wireform up a bit to ensure the ball rolls over and records it.
It is best to take off the apron to use a ball to test the trough switches out a good 30 times to make sure it records each time. One can just be intermittent and testing those trough switches one time will not catch a problem with them.
Exactly! It doesn't make any cense to me. I removed the slot machine scoop and ran the ball over the switch for about 10 minutes and according to the switch test it's fine. It chimed every time. When the ball goes down the scoop the slot machine on the display doesn't start. nothing happens for about 30 seconds. The machine then starts searching for the ball and eventually pops it out.
