Hey everybody - got a strange audio issue on an Attack From Mars.
Occasionally (lets say 30% of the time) when you destroy the mothership during a game and it goes through the detonation animation and light show, the sound will drop entirely for about 3 seconds, then you hear the typical boot up "DING" sound and then the sound picks right back up mid-game but the volume is higher than it was before. After the next ball drain, the volume reverts back to its normal state.
my gut tells me this is some sort of voltage surge or voltage drop that's causing the Audio portion of the audio/video board to reset?
Keep in mind the following details - the issue does not in any way impact the DMD, the lighting on the game, the gameplay itself, etc - this is ONLY a sound issue. The issue never occurs at any other point in gameplay or attract mode - it ONLY happens during the mothership detonation sequence. The capacitors LOOK fine but are clearly original - could this simply be the caps? which ones? every one on the board or just the big filter caps? Anything else I should consider?
I have done the following:
removed the Audio/Video board and reflowed solder at all connector pin locations and anywhere else that looks suspect
reseated all connections.
