Just added AFM to my collection. She's a beauty, but I've noticed that the solenoid that ejects the ball out of the saucer area is firing it so strong that the ball is bouncing back into it a few times before it finally stays on the wire ramp and rolls down. Adding to that, the powder coating on the wire ramp is being damaged by this receptive action. The solenoid meets the factory requirement for power. We added one washer to each screw under the playfield, but it's still bouncing back. The other suggestion I've received is to double up on the spring. Any other people every experience this and if so, how did you correct it? I'm sure it's simple, but I'd like to find someone else that had this issue and a real world fix for it. I noticed my trough solenoid does this sometimes too (the bounce back) so I might be adjusting both.
Thanks in advance...
BSL
