I brought home an AFM (original) this week, and a credit dot has popped because the right gate is staying closed. I've searched the forum and found several threads pointing to one of the left switches leading up to the gate, but that unfortunately doesn't appear to be the answer because the right gate doesn't fire in solenoid test mode.
I've replaced the fuse at F118 (though it tested fine), I've resoldered the lugs on the coil, I've reseated the cables at J119 and J120--so far nothing has seemed to work.
I also took the assembly off the underside of the playfield to see if it was trying to fire and the springs were bad, but I saw no movement at all.
Should I be replacing the relay coil? ... I feel like that's never the answer ... so before I order one, what else should I be testing/checking?
EDIT: Solved--the issue was the wire connection between the right gate coil and the left gate coil had broken off the left gate coil.
