Situation:
- Fully working and stable, prior to ColorDMD install, AFM w/1.13B ROMs.
- ColorDMD v1.3 purchased in 2012 and just installed. Board came with v1.3 firmware and was upgraded to 32-bit key and 3.1 firmware after installation.
- No mods in AFM other than Bill Ung v1.0 saucer kit.
Prior to the ColorDMD install, the game was stable. After install of the ColorDMD v1.3 w/v1.3 fw, the game randomly reset and there was image corruptiton on the ColorDMD. After then upgrading the ColorDMD key to 32-bit and installing v3.1 fw, all image corruption is gone but the game still randomly resets - sometimes multiple times in a row, during a game, or after hours of stability.
On startup and reset the display shows:
50041 1.13B (while running the startup tests and showing progress bar)
then
541 100308 02049 appears below the above information once the test progress bar is complete. Is this a checksum error?
As part of simple troubleshooting, I've removed power to the Bill Ung board, but the reset problem continues, so the Bill Ung board does not appear to be a factor.
The v1.13B ROMs were installed several months ago in preparation for the ColorDMD install and support. As an aside, the machine had v1.0 or 1.1 ROMs prior and the SOL hole would eject STDM about 75% of the time. Since the 1.13B ROMs were installed, it only ejects STDM about 10% of the time. Strange, but welcome.
Any ideas why the machine is resetting post ColorDMD install?
Thanks.
