So at my last party someone came over and reported that AFM the left flipper wasn't working. Quick investigation revealed that it was seized because the coil had partially melted. I replaced the coil to find the flipper was dead, figured out that it had blown the fuse as well. Replaced the fuse (fully expecting to encounter more problems), and weirdly it seems perfectly fine right now. That is what has me worried, is is possible a coil could have been the cause of all these problems? I guess I was expecting the new coil to lock on and have to trace down problems with a transistor upstream from the coil. I played for about 20 minutes and neither saw (nor smelled) anything wrong, flipper was working fine.
