(Topic ID: 160342)
AFM left popper false triggering
By Alex1061
  • 7 posts
  • 5 Pinsiders participating
  • Latest reply 3 years ago by pincredible
#1 3 years ago
Hi there,
The left popper will thump away randomly and stop, often after the ball has drained
it will thump a couple of times and then it will be quiet for a while.
It is playing fine, keeping track of the balls ok, it is just irrating
I have done a thorough switch test on the optos and the wire switch in the trough.
I have checked the diode.
Appreciate any help I can get.
Cheers
#2 3 years ago
Most likely you need to adjust the leaf switch under the pop. You need to move metal contacts further apart on switch under pop in question.
#3 3 years ago
Pound on the playfield a few inches from the pops and see if the vibration triggers it.
#4 3 years ago
I should have said Left popper assembly, its the upkicker thats false triggering, the one that returns the ball from under the space ship.
I will try to edit the forum topic name
Sorry
#5 3 years ago
Quoted from Alex1061:
Sorry
Do you have a ColorDMD installed?
#6 3 years ago
Sorry
Well in that case I would adjust the switch or if opto clean them up in the popper assembly. I see you checked this as resolved. If you did get it taken care of please share what you did to help others that may have a similar issue in the future.
#7 3 years ago
Dirty vuk opto. Use switch edges to see if the opto is opening when it shouldn't. Remove vuk mech, clean and reassemble. Test again. If problem persists check connectors for bad contact.
$ 209.00
PinWoofer
$ 125.00
Cabinet - (Alt) Translites
FlyLand Designs
