can anyone help ,, where can i get 6v and 12v on AFMLER i want to put spotlights and other mods in
thanks
thanks
Just hanging your 6 volt Lamps off the exisiting relevant GI lighting string.
I would not do this is your game is all or mainly incandesant bulbs. If you have LEDS then go for it.
12 VDC unregulated use J138 Pin 2 is 12VDC and pin 3 is ground
Check with multimeter before using and do not use the 12 VDC regulated supply unless you want your Machine Toasted.
My WH20 has 17 additional GI leds and the overall load is still way less than using the factory incandesant lighting.
This page was printed from https://pinside.com/pinball/forum/topic/afm-le-r-power-sources-6v12v and we tried optimising it for printing. Some page elements may have been deliberately hidden.
