Still no flippers.
This is what I know.
The j119 connector is the power out to the flippers as well as 2 coils left gate and right gate and a diverter. None work. They are 50v power.
The j120 connector is the ground side and that connector also looks good.
I checked the flippers for power by grounding them out and they work.
I checked the ground wires from the flippers to the j120 connector for continuity and they beeped out ok. So there are no breaks.
The flipper buttons test OK in the switch test.
The other 50v coils in the game work.
I switched out the Driver board with MB but that didn't help.
I've reseated every connector in the game, twice. Including the ribbon cables.
The coin door shuts off the 50v when opened and the led on the driver board goes out. When shut it goes on.
It appears it's working ok as the other coils and flashers work when the door is closed.
I'm completely out of ideas.
Could it be something with the Coin door interface board?
or The CPU?
Those are the only things left.
Any ideas?
