Hi all I restored my AFM and the only thing that is not working is the lights on the front door everything else is on like start light on any help would be great
Lower left corner of the power/driver board. J119. 3 pins. center keyed. Purple/White-Purple wires just as Nathan said.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/contact/
Quoted from Williampinball:On the left lower 3pin is J104
J104 is on the lower left hand side.
Whoops. I was thinking of WPC vice WPC-95.
Yes, J104 is correct.
Yes.
Meter on AC power, expecting less than 20VAC.
One lead on the violet wire connector.
Other lead on the white-violet wire connector.
Should read about 6.3VAC.
Ok I checked and no power going there ,my other ones are reading 6.7 AFM is not ?
You can use this image to test for power and continuity at various points.
http://www.pinwiki.com/wiki/index.php?title=File:Wpc95PinWikiGI-String5-Purple.png
Have you removed and buzzed F110?
Do you have GI power between pins 6 and 11 of J106?
Quoted from ChrisHibler:You can use this image to test for power and continuity at various points.
Yes it's was the F110 fuse so I went up too get one and she's working great now ,thanks so much for your help your the best
This page was printed from https://pinside.com/pinball/forum/topic/afm-door-lights and we tried optimising it for printing. Some page elements may have been deliberately hidden.
