(Topic ID: 234772)
Aerosmith toybox problem.
By pinball_mutha
  • 10 posts
  • 6 Pinsiders participating
  • Latest reply 2 years ago by wtatumjr
#1 4 years ago
Hello! I've looked in the forums for anyone with the same issue and couldn't find anything.
I'm experiencing a problem my Aerosmith premium pinball. When the lock is lit and it shoots the ball into the toybox, it just pushes the ball back out and the lid stays open. Then if I hit the lock again it says 'reloading toybox 1' shoots the ball into the toybox again just to repeat what just happened.
I've looked at all the switches on the motor and in the toybox and everything registers in test with no problems.
Thanks for any help!
#2 4 years ago
Quoted from pinball_mutha:
Is the opto inside the toy box working?
#3 4 years ago
Thanks, yes all three in the box are registering.
#4 4 years ago
Do you have the correct amount of balls in game, and double check you trough opto’s
#5 4 years ago
I have seen this problem as well. Checked the switches for the position of the lid and everything. It definitely knows the ball loaded, but ejects it out after it loads. The lid does close down afterwards, but not sure I understand what it is doing.
#6 4 years ago
Thanks, there are six balls in the machine.
I'll check the lid, but it looks like there is only one switch and it's active when the lid is closed.
#7 4 years ago
Did you ever figure out what was going on?
3 months later
#8 4 years ago
I am seeing the same issue, started immediatly after I upgraded the code to 1.0.7
2 years later
#9 2 years ago
I never found a solution to this and it seems to eject all balls each time you reach the number that should be in the toybox.
#10 2 years ago
Make sure you're level left to right but I guess you've done that. It really sounds like an opto problem, though I know it works in test mode. Make sure the sight holes of the opto are clean. Check the receiver side of opto. If they are secured by a single lock nut realign the receivers to the sight holes and retighten.
$ 8.50
Toys/Add-ons
$ 150.00
PinWoofer
Sound/Speakers
$ 69.99
Toys/Add-ons
$ 29.99
PR Mods
Sound/Speakers
This page was printed from https://pinside.com/pinball/forum/topic/aerosmith-toybox-problem and we tried optimising it for printing. Some page elements may have been deliberately hidden.
