Quoted from ATLPinGuy:I assume the answer to this may be easy (and my apologies for not looking it up) but how do yo7 attach a sub to your Aerosmith? Is it as easy as plugging it in?
I use a piece of speaker wire, install alligator clips on one end and clip them to the speaker terminals on the cabinet speaker. Alternatively you can solder the wires on the speaker.
Route the speaker wire out of one of the vent holes near the back of the cabinet. You can sometimes slip the wire under the mesh, other times you need to pop up a staple.
Route the speaker wire to one of the high level inputs on the sub (either right or left will do). These are the connections that look like speaker wire connectors on the back of some stereo speakers. Make sure you get the set labeled input.
Make sure to pay attention to polarity. Red on the sub is + and typically yellow on the cabinet speaker is + but look for the markings on the speaker. If you don't keep the polarity the same on the sub and cabinet speaker, they will work against each other, resulting in less than awesome results.
Adjust the crossover and volume on the sub to blend in with the speakers in the game. Too high of a crossover will result in boomy or muddy bass. Too low and you won't gain much bass from the sub.
