Quoted from WJxxxx:Having seen the code update for GotG, and how awesome it is - I really hope that the update for AS (as the modes are almost a direct copy) is along a similar vein, and we don't have to wait too long for it.
NEW CODE RELEASED TODAY!!!!
Unfortunatly not a lot of fixes or features added...not that the game isn't already pretty solid.
V1.05.0 - April 2, 2018
- Fixed a time out bug in "Back in the Saddle" where, during the "final shot(s)" sequence, the pop bumpers turned off the lit shot(s).
- Fixed a problem where the game could reset if the display tried to render too many layered images after a foreground display effect was finished running.
- Fixed a bug where the flippers where allowed to change the bottom lane lamps during diagnostics.
- Changed the default speech/music attenuation settings on French games.
- Changed the default ball save settings on China games.
- Fixed a problem where combo shots to the left scoop during Love in an Elevator Multiball were not being scored correctly.
- Removed unused adjustment.
- Added an upper playfield targets completed audit.
- Added AD_TILT_DEBOUNCE adjustment in ms for tilt bob debounce
- System v1.97, nodebus protocol change and node board firmware update.
- At the start of each ball, check if the stgl5000 codec chip has reset due to static discharge and reconfigure register if needed to recover audio playback.
- Changed debounce logic/timing to prevent double start button detects.
- Added USA_12 Coinage 1/$0.25, 5/$1.00
- Added audit for total number of one, two, three, and four players games
that have been played.
- Improved sound proccessing
- Interactively update the backbox brightness while changing Attract Mode,
Game Play, and Service Mode adjustments in the service menu
- Added adjustments for backbox speaker bass/treble, cabinet speaker
bass/treble, and cabinet/backbox speaker balance to service menu
UTIL->VOL. Speaker balance allows lowering the volume level of cabinet
speaker or backbox speakers vs. the other.
- Improved sound issues at power up
- Reworked boot time displays for node board firmware update and locating node
boards.
- Added boot time display for overcurrent detected (shorted coil or LED) on
node boards.
- Added support for dynamic detection and isolation of overcurrent coils or
LEDs. Previous behavior would disable all coils and LEDs for 1/2 second each
time a short was detected. New behavior will determine the short coil and/or
LED and disable only the offender.
- Added tech alert for overcurrent coils and LEDs on node boards. New
diagnostic test to retest node board and report with coils/LEDs are drawing
too much current. Excessive current draw could be the result of a shorted
coil, an incorrect replacement LED/incandescent bulb, shorted light socket,
et cetera.
- Every 15 minutes during attract mode overcurrent coils/led will be rechecked
and returned to service if operating correctly.
- Added adjustment for "GAME PLAY B.BOX BRIGHTNESS"
- Renamed "BACKBOX BRIGHTNESS" to "ATTRACT MODE B.BOX BRIGHTNESS"
- The deprecated BILL VALIDATOR adjustment has been removed.
- Updated Norway coin door to 1/5/10/20 Kr for left/center/right/4th
slot.
- Updated Sweden coin door to 1/5/10/2 Kr for left/center/right/4th
slot.
- Added Sweden 3 credit pricing 1 credit for 10 Kr.
- Updated Sweden dip switch setting (0x0B) default to Sweden 3 pricing.
- Replaced hardware version number with OS version number on diagnostic
screen.
- Added a message LOCATING NODE BOARDS. This will display if a required
node board is not discovered, previously it would incorrectly state
UPDATING NODE BOARD and UPDATE FAILED. The node board number(s) of
missing boards will be displayed and updated as boards are found.
- Updated UK pricing
- Added China dip switch setting
- Added support for China currency and pricing.
- Added support for eWallet psuedo ticket dispenser device. Only selectable
for China dip switch setting. The ticket and redemption systems will
ignore this device if selected.
- Added support for new headphone jack accessory
- Added SWITZERLAND 3 pricing (the new default for games that are DIP-switch set for SWITZERLAND): 2/1 SwF 5/3 SwF.
