(Topic ID: 184386)
Aerosmith owner? Then walk this way!
By TimeBandit
  • 2,976 posts
  • 298 Pinsiders participating
  • Latest reply 16 hours ago by BMHouze
  • Topic is favorited by 123 Pinsiders
There have been 472 images uploaded to this topic. (View topic image gallery).
There are 2976 posts in this topic. You are on page 16 of 60.
#751 2 years ago
Quoted from Who-Dey:
Congrats on your new AS game! It is a killer game and you are going to love it.
Thanks who-dey I was originally going to get star wars premium which I still like but I decided to switch to Aerosmith and I am very happy with my decision really enjoying the game so far.
Quoted from rotordave:
No, that’s called “a win”
Take it with both hands.
Legitimate strategy.
rd
I am really happy I found this out I will definitely be using this into my strategy for tournaments now.
#752 2 years ago
Glad you are enjoying the game, I really like my Pro model a lot and I don’t think I will ever get rid of it. The more you playnAS the more addicting it becomes. It’s not anything fancy code wise but the game is just fun and it shoots really good.
#753 2 years ago
Quoted from vireland:
Got into test mode (diag) and do the ball trough test (I think it's labeled CLR with a picture of a ball) to see if it knows how many balls are in the trough as you eject each one in the test mode. Likely you have a loose-flaky opto and that test should help you visualize it.
The test works fine, but i notice that the ball very often hangs at the end of the ball through (top), see picture.
Any idea how to fix that ??
#754 2 years ago
Quoted from sirlonzelot:
If the ball is not ejecting all the way out into the shooter lane maybe it’s just not ejecting hard enough. There should be a setting called ball trough eject setting in the adjustments menu. You could try raising that up a little and see what happens maybe.
#755 2 years ago
Also have a look at the mechanism. Make sure it moves smoothly if not it should be easy enough to see why.
#756 2 years ago
Can’t find this adjustment
#757 2 years ago
I’m not home right now so I can’t look for it but I will later.....sorry about that. I know GB has a trough reject power setting but I’m not sure about any of my other games. You could call Chaz at Stern and ask him what might be going on. They might be back to work today possibly?
#758 2 years ago
Now I have an other problem. I only hear the bass and a summing tone from the backbox speaker
Any idea ?
#759 2 years ago
I'd check to make sure that the coil eject isn't binding by manually moving it up and down to see if you feel any resistance. Also, did you change the coil pulse power to low on setting 43 of the main adjustments menu?
Any idea ?
Open the backbox panel and follow the connections from the speaker panel back to the system board and see if they've come loose. Your cabinet speaker is giving the bass, but the cabinet speakers aren't working. So either an unplugged/loose wire or a blown amplifier chip.
#760 2 years ago
I think the reject problem is sloved. I had installed a pu shooter lane protectors. I removed it and i had no problems till now.
For the sound, I checked the connection but they are all ok. The cabinet speaker works but not the backbox speakers. I think the CPU board has a damage
Hope my dealer can fix it soon
#761 2 years ago
Use the cliffy shooter lane protectors and you won't have that problem, but your shooter lane will remain protected. Email him since they're not on his site yet. Email crinear@comcast.net and ask for Aerosmith shooter lane protector (and the toybox eject protector while you're at it) and he'll send you an invoice.
You might want to also check with pinball heaven and/or ministry of pinball since they're listed as carrying some of his stuff here:
http://www.passionforpinball.com/protectors.htm
On the sound, one other thought I had is did you change the settings at all for the music on the menus? I don't think it could strip out all the mid and high end, but maybe if you maxed out the setting it could...
#762 2 years ago
Anyone have these issues on the pro?
1. 2 or more balls getting stuck in the elevator during MB
2. Ball gets tossed into the toy box and then the machine can't find another ball. After about 6 ball search sequences it dumps the toy box.
#763 2 years ago
Quoted from pinden007:
1. Yes. Happened to me once.
2. No. I would check the sensor/switch in the toy box.
#764 2 years ago
2 has been reported numerous times. I don't recall the fix but search this thread or the other AS thread.
#765 2 years ago
I had this issue when I got mine, it was a bad node board. Stern sent me a new one after I contacted my dealer.
Edit: The sound issue is what I was referring
#766 2 years ago
I put some Mylar over the shooter lane and look how it holds
Quoted from Chisox:
That is interesting, after reading that I put back the cpu board to my machine and voila my sound is back. I don’t know why, but the next time I have this problem I will unplug the node boards to See if they causes the problem
Thanks for the help
Greetings
#767 2 years ago
I'd suggest most likely cause of the fault is that it can't detect any balls in the trough.
Could be caused by a dodgy opto, but MUCH more likely the connectors to the boards on the trough have come lose, or oxidised. Simply disconnect and reconnect all of the connectors leading to those boards.
Happens on virtually ALL Sterns.
#768 2 years ago
#2 is a connector under the toy box. There are two of them under there, one of them has come loose, can't remember which one.
Reseat it and you are fine.
If you can't get to that, then make the ball lock virtual until you find someone to help you.
#769 2 years ago
I just listed a nice Aerosmith Pro with Dirty Donnie inner cab decals and a few other amenities. You can see it here: https://pinside.com/pinball/forum/topic/for-sale-aerosmith-pro-20
Thanks,
Bob
#770 2 years ago
My sound issue is back again, I disconnected the node boards. But the same.
Seems that I have a bad cpu board
Hope that I a get a replacement very soon ...
#771 2 years ago
Did anyone knows, how many floors are needed to complete elevator multiball ?
#772 2 years ago
8 flrs. Never did it yet.
#773 2 years ago
Did anyone have a good color for powder coating the pro ? I think of a darker blue which will match with the cabinet but not so good with the playfield
#774 2 years ago
Try purples
#775 2 years ago
Look at post #687 on Page 14 of this thread. I think it came it amazing.
#776 2 years ago
I have some others
Quoted from Rascal_H:
That looks great, but my powder man didn’t have this powder
#777 2 years ago
The sparkle ones really look great instead of just a flat color.
#778 2 years ago
Quoted from ZEN:
Thx, it was done by a guy local to me, he is good and has a nice setup.. it's a really good look imo.. Yeah I know I need some scorecards...
That looks great! Do you have any details on the powders and metal flake he used?
#780 2 years ago
Quoted from modfather:
use illusion blue by Prismatic powders
Do you have pictures how this looks on the machine?
#781 2 years ago
i had robert do this blue it looks amazing.
#782 2 years ago
Mine is a powder called disco nights, prismatic. It is a two stage with an ink black base, it looks navy blue from 6 feet away, it's really stunning.. I had a clear powder shot on the top as well to give a little depth..
#783 2 years ago
That looks real cool. Does it mean first to powder in black and then the Disco night?
#784 2 years ago
Yeah, it's a bit of a process but looks great. My guy can do this color for others if anyone wants it he said, I can get a quote for anyone that wants it.. I had him do the speaker panel and coin door too..
#785 2 years ago
Looking to join this club shortly....
#786 2 years ago
Quoted from Meegis:
Yup! Me too. Ordered and on its way.
#787 2 years ago
Zen or Rooftop - can you take a pic of your full machines with the blue powder coating?
They look good!
#788 2 years ago
Quoted from pinnyheadhead:
They look good!
Yes please! I would also like to see full machine pictures. Also, did you guys have clear applied as a 3rd coat?
#789 2 years ago
They look good!
will post some this weekend
#790 2 years ago
My apologies, mine was the CPU board as well. Luckily the replacement fixed the issue and the game has been perfect since. Also there is a small jumper from c15 to a pin just to the right that wasn’t included on the new board from Stern that I needed to use from the old board. If your backbox LEDs don’t work that’s why.
#791 2 years ago
Deposit made.
Now to figure out delivery.
#792 2 years ago
Quoted from Chisox:
I found the problem, it was a bad active subwoofer. Since I disconnected it, it works fine
#793 2 years ago
Hi All, I've had my NIB Aerosmith Pro for about two months now and just this week it's started to make an annoying "buzz/beep" sound sometimes when selecting songs. (The best I can describe it is the sound similar to when a phone interferes with with a hi-fi system) I've done the obvious and checked all the connections. It's bearable, I just hope it's not leading to a bigger problem. Has anyone else had the same issue? Any help/advice would be appreciated. Thanks
PS- Have a laugh at my kitchen setup
Added over 2 years ago: Update: Problem Solved
Updating the code seemed to do the trick. My machine came with the same code I downloaded (1.03), but I've noticed a heap of more sounds since the update. (Crowd cheering mostly) Thanks for the beer tips and no, the glass doesn't fit inside the fridge (especially when there's beer in there) you funny buggers ?Cheers
#794 2 years ago
Why would I laugh?
#795 2 years ago
Quoted from gamera9:
Why would I laugh?
Because I've got to move my fridge when I need to take the glass off
#796 2 years ago
Quoted from Bruce_Pickle:
... you could actually crack open beer from the fridge during play. Love it!
#797 2 years ago
Nah. Just open your fridge door and slide the last foot of the glass into the fridge when you take it off.
You’re welcome.
#798 2 years ago
Quoted from MacLean:
I was thinking the exact same thing, it's close enough to grab a beer while cradeling the ball
#799 2 years ago
I was thinking if you got rid of the fridge completely you might be able to fit another game.
#800 2 years ago
Quoted from cooked71:
I like how you think
$ 69.99
$ 54.99
$ 199.00
Lit Frames
$ 7.95
