(Topic ID: 285584)
Aerobatics Add-a-Ball: How should it work?
By callmedoor
10 months ago
  • 3 posts
  • 2 Pinsiders participating
  • Latest reply 10 months ago by callmedoor
#1 10 months ago
Hi all,
Does anyone have an information on how Zaccaria's Aerobatics ruleset works? Specifically, if I have it set to Add-a-Ball which conditions should trigger the ball count to step up on the backglass?
Right now, it steps up when I achieve a replay, but doesn't step up when I gain a "Bonus Ball". Instead, it acts like a "Same shooter shoot again" type of trigger where the ball count doesn't step down and I replay the same ball.
I don't know if this is the intended way that Add-a-Ball is supposed to work or not as this is my first EM, so any help is appreciated!
#2 10 months ago
Hi callmedoor
from what I read from You, ipdb (pictures and text) and looking into the schematics I say: To the different ways "Replay-Mode, Add-A-Ball-Mode is Extraball-Mode, Novelty-Play-Mode and true Add-A-Ball-Pins" - (A) I learned "Aerobatics" can be played (in Replay-Mode) making Replays and (one) EXTRA-Ball (called Bonus Ball) with a ball we are playing, having on the playfield - in play. (B) I learned "Aerobatics" may come as a true Add-A-Ball-Pin not having an Replay-Counter. (C) I learned "Aerobatics" Replay-Pin can be set / changed to true Add-A-Ball and still gives the chance to make one Extraball (called Bonus Ball) with a ball in play. This (C) way is new to me - we must check if this really is the truth.
Here https://www.ipdb.org/showpic.pl?id=24&picno=77594 we see on the bottom the 1 2 3 4 5 6 7 8 9 10 Game Over indicating "true Add-A-Ball, a new game starts on "Balls to Play 5" then as we play it slowly steps down to 4 then 3 ... . On the right of the ipdb-picture, a bit up we see text "Bonus Ball" - to me this is exactly the same as we are used to read "Same Player shoots Again (an Extraball)".
See here https://www.ipdb.org/showpic.pl?id=24&picno=67174 - the backbox of a (true) Add-A-Ball pin - NOT HAVING an Replay-Counter. Question: In Your pin - is there an Replay-Counter ?
When You change the plugging to Replay-Mode - Question: Can You make that "Bonus Ball" to light up ? and You get what we normally call an "Extraball" ?
Normal Extraball: We are playing a ball, make "Extraball" lighted - loose the ball - bonus is counted down, given - stuff on the playfield resets - ball is kicked over to the shooter-alley NOT stepping to next player / next ball - and I then play the Extraball.
callmedoor - please answer my two questions. It would be great when an owner of an Aerobatics-Pin would chime in and tell us about the logic in play.
Side note: The ipdb-schematics is a bit confusing - the mentioned "Extra Play Unit" is (to me) Replay Unit --- many strange wording and Argh - GAME-RELAY - I always have problems understanding an GAME-Relay. Greetings Rolf
#3 10 months ago
Quoted from rolf_martin_062:
Hi callmedoor
Rolf,
I would also love for someone who owns one to chime in and give us some direction. I can tell you that I have an Aerobatics that has both the Replay Counter/Stepper AND an Add-a-Ball mode with my current machine set to Add-a-Ball.
In regards to lighting Bonus Ball in Replay mode, yes, it works as intended.
I don't know if this helps, but in Add-a-Ball mode I just lit Special AND Bonus Ball at the same time. When I trigger the switch for Special without Bonus Ball lit, it replays the same ball as well. So, in this particular case I had both lit and drained and I only received "Same player shoots again" where the ball counter didn't step down, but stayed on the current ball. I would think in Add-a-Ball the Special switch would add a ball and then on drain it would add another ball giving me TWO balls. However, I don't know if that is how the game is wired.
I have a hard time reading schematics, but I am learning. Bear with me.
