Hi All
I have a Zaccaria Aerobatics on loan and I've noticed that the feature lights (LEDs) in a couple of areas are always dimly lit. It has LEDs and I've measured around 3V on the lamps that are dim and should be off. I've attached a photo of the problem - in the bonus area at the bottom the middle one (50000) is correctly the lit and the rest (apart from 80000?) are dimly lit. Similarly on the Loop the Loop area (middle left) only the bottom lamp should be lit and the rest (apart from ABCDE insert?) are dim. Other areas such as ABCDE and the lamps around the top hole are ok. Also in game the features increment correctly but the remaining lamps are dim.
I appreciate that LEDs may highlight the problem but I'm pretty sure when I first had the machine it was fine.
Many thanks for any advice to t/shoot this.
