My Wpc 95 AV board is working but the volume is very low. I've swaped boards with another machine to verify its on the AV. I did the high voltage rebuild and it's still the same, working but low sounds. So where is the bad component or what is the bad component?
I don't think the high voltage kit has the item that is the culprit. I also replaced all 4 of the big caps. Same as before. If I turn volume up at coin door it sounds fine but I have to have it all the way up to sound how it would about in the middle level on a normal working game. I didn't do the dmd section rebuild as dmd looks fine (transistors)
