(Topic ID: 176412)
Advice sought for redoing game room / basement
By Nokoro
2 years ago
  • 70 posts
  • 27 Pinsiders participating
  • Latest reply 2 years ago by poppapin
  • Topic is favorited by 10 Pinsiders
    There have been 39 images uploaded to this topic. (View topic image gallery).
    There are 70 posts in this topic. You are on page 2 of 2.
    #51 2 years ago
    Hired a contractor! Work starts beginning of April.
    I'll take some better before pictures of the basement and post later to compare to the after.
    #52 2 years ago
    So, here comes the before pictures with the plan of what we are going to do. We are going to widen the door to the basement to 32" to more easily get pins in and out. We are going to add a landing from the second stair at the bottom as ls1chris recommended. When you turn the corner, you are going to be facing a custom built bar against the far wall to the left of the closets. Before picture of that area:
    The bar is going to be L-shaped and about 60"x70". It will be two-tiered with a lower working countertop for the "bar tender" (me) and a higher countertop for the "patrons". We'll have some track lights above the bar. We're adding an outlet in the closet for a minifridge for storing ice, etc. The ping pong table will be gone. A small TV will be mounted to the wall behind the bar.
    Moving counter-clockwise:
    This will be the new area for the pins. I can fit 4 against the wall which, right now, is to the left of the TV (which will be gone and mounted over the bar).
    I'll have a service light over the pins on a separate switch.
    Continuing to move counter-clockwise, where the pins are now, we are going to mount a larger TV on a swivel mount at the left most point on the back wall:
    The TV will swing out so guests seated on a couch (where the right wall and Hobbit decal is now) can see the TV. We will either get a sectional for that right wall that makes an L-shape out of the wall and facing the back wall, or we will get a couch and have some nice swivel chairs in the area instead.
    Around the corner, we have this little nook tucked away between the stairs and the utility room:
    Right now, we put the kitty litter there. We are going to make this my daughter's new art area and put a screen to block off the area where the TV and couch / sectional will be. The cats will have to do their business elsewhere.
    Some other features of the whole basement: We will have a Pergo laminate floor. The drop ceiling will be removed, and everything above will be sprayed with a black dry fall paint. We will have canister lights throughout. All new flat walls with new molding.
    That's the gist of it. Getting very excited!
    #53 2 years ago
    A question for folks: Right now, I have perfectly sized carpet sliders on the bottom of my pin legs. Does anyone know what type to buy for a hard floor to allow the pins to slide somewhat? By that, I mean does anyone know the exact product to buy that will be the right size? I've seen hardwood sliders out there, but I haven't seen them in the exact size of my carpet sliders (though, I haven't looked that hard yet). Thanks!
    #54 2 years ago
    My pins are all tucked in for the start of work tomorrow. They'll get wrapped up some more. I just wanted to make sure they had heavy blankets to keep them comfy.
    The hardest part about this -- not playing for 5+ weeks while the work takes place.
    1 month later
    #55 2 years ago
    The basement is done! Thanks everyone for all of the advice you gave. Here are some pics:
    First, the landing, leading into the basement: more room now for getting pins up and down.
    Now, in counterclockwise motion, the bar, the pin area, and the media area:
    The ceiling is matte black with some cannister lights:
    My daughter's art area is in a nook behind the stairs. We painted a chalk wall for her, and she used it:
    More pics of the bar:IMG_1581 (resized).JPG
    #56 2 years ago
    I'm very pleased with how it came out. Plus we have room for one more pin!
    #57 2 years ago
    Wow, turned out really nice!! Did you do ceiling or contractor? I'm trying to do my basement on a budget.
    #58 2 years ago
    That basement is damn nice! Excellent design and sure to bring years of enjoyment
    #59 2 years ago
    Thanks guys. I'm really happy, though I have to say, the process was really stressful. I'm glad I can now just relax and enjoy the space.
    poppapin We used a contractor for everything, including the ceiling. He sub'd that work out to a painter. If you haven't done something like that before, I would recommend hiring someone. The ceiling work was really messy. The painter wore a fully suit and respirator and painstakingly sprayed every nook and cranny of the ceiling. The dry fall paint leaves a ton of black dust behind, which easily cleans up, but it looked like a bear of a job.
    #60 2 years ago
    Quoted from poppapin:
    Quoted from Nokoro:
    It really comes down to whether the space is empty or not. If it isn't get a pro, if it's the beginning of work do it yourself. You can buy a cheap paint gun or rent a big one form lowes and pump it out quick. There isn't anything special aboot it...just takes time. I had a guy do my last one and i did this one myself with the cheapest paint imaginable..can't see any diff'rence.
    #61 2 years ago
    Huge improvement!!! Very awesome! Would love to know what it ended up costing ballpark if you felt like sharing.
    #62 2 years ago
    Quoted from Mbecker:
    Sure. Ballpark, it was about $20k not counting the cost of furniture. That's less than the cost of a Magic Girl. It was about a 4-5 week job.
    #63 2 years ago
    Nice space. I have about 1700 sq feet in my basement that needs to be refinished. I will be doing it myself over time but love seeing what others have done. My ceilings are low also so I might do the same. Mine are just tall enough though to raise my playfields so I haven't decided yet if I want to remove the drop ceiling.
    That carpet on the stairs, how far does it go? In your pics you can only see it on the stairs and the landing, is that the extent of it? I currently have carpet with a thick pad and love the warmth. The previous owners (company that flipped the house) used a really crappy grade carpet. It stains really easy and is hard to keep clean. I have kids (8&9) and 2 dogs + 2 cats so it's a bear to keep clean. I am thinking vinyl plank flooring. What kind of flooring did they use in there?
    #64 2 years ago
    Quoted from Meph:
    Yes, the carpet is only for the stairs and landing. We used a relatively cheap but commercial grade, nylon carpet. It should hold up well taking a hand truck up or down or gently sliding a pin down. For the main flooring, we used Pergo. I think there are cheaper laminate floors, but we have had success with Pergo and didn't want to risk it.
    It sounds like your drop ceiling is a bit higher than mine was because I couldn't raise a playfield without moving ceiling tiles around. It was a pain. Nevertheless, I really love the open black look. I think it opens up the space a lot and things feel less claustrophobic.
    #65 2 years ago
    Quoted from Nokoro:
    And, the one more pin was just added . . .
    #66 2 years ago
    Nice looking games room/media room area. It looks great and the way you have gotten the roof painted looks bloody awesome!
    Nice line up of pins too!
    #67 2 years ago
    Quoted from Nokoro:
    Not bad! Bet you're stoked to have it done and be able to enjoy the lineup!
    #68 2 years ago
    Looks great so far. One thing to consider would be some inexpensive signage to highlight your new space. I recently picked up these rather inexpensive ($40) I think LED signs for a similar barely lit stairwell like yours. They hang up easy and since they are LED and battery powered you don't have to run wires. I think they really bring a nice accent to a boring hall of stairs. Just a thought.
    #69 2 years ago
    Quoted from Micky:
    Thanks. Yeah, doing the ceiling matte black was a great choice for this space. I'm really happy with it.
    Quoted from Yelobird:
    We definitely need some wall decorations. I saw those signs and love them, but the way they mount doesn't work for us. I like what you did with hanging them in the stairway. It would prevent me from getting pins down, however, unless they come on and off really easily.
    #70 2 years ago
    Hobby lobby has some of those!!
    $ 29.95
    Pinball Photos
    $ 129.00
    LED OCD
    $ 349.00
    $ 159.99
    £ 75.00
    PinballToys
    KAHR.US Circuits
    € 4.99
    Multigame
    $ 5,599.00
    Ghostbusters Pro Out of stock
    Operation Pinball
    $ 315.00
    liorillusion
    $ 69.99
    $ 219.00
    $ 90.00
    Lighting - Under Cabinet
    $ 11,500.00
    $ 12.00
    Meph's Mods
    $ 229.99
    $ 7,999.00
    Great American Pinball
    $ 48.00
    TheDudeMods
    $ 18.95
    Flashinstinct
