New! Dark mode!
(Topic ID: 259686)
Advice on installing NOS Translite in TZ please
By pinballphile
10 months ago
  • 10 posts
  • 7 Pinsiders participating
  • Latest reply 10 months ago by pinballphile
#1 10 months ago
I recently found an OEM NOS translite for my TZ and was wondering if anyone had any helpful hints and tips on installing it into the translite glass assembly to avoid damaging the new translite please.
Should I also replace the bottom lift channel (or any of the other translite trim pieces) while I am at it?
Thanks in advance for your suggestions!
#2 10 months ago
Remove plastic trim. Clean glass. Put on plastic trim. Done.
Replace any trim that is broken or cracked.
I like to lay the glass down, back of translite up with trim installed. Gently smooth the translite with my clean hands from center to edges. So it's nice and flat.
#3 10 months ago
Quoted from LTG:
I think you forgot the <remove old translite> and <install new translite> steps
#4 10 months ago
Quoted from LTG:
Thanks LTG. I didn't realize the process was that simple--the plastic trim pieces seem to be on pretty tight and I thought there would be a trick to getting them on and off.
If you would suffer a couple other questions please: in terms of cleaning the glass, before putting on the new translite: Do I need to avoid ammonia-based products? (I realize I'm obsessing over the details.--I just don't want to do something dumb to mess this up).
Finally, the reason I'm replacing the translite in the first place, is that part of the "Tallking Tina" face on the old translight was rubbed away by the long clear plastic post screwed into the bulb board behind the translite. I got rid of that post to avoid further damage, but was wondering what purpose it serves, since it appears in my STTNG as well. Is it there just to keep the bulbs board from swinging out too far when you access the PCBs?
#5 10 months ago
Use this
#6 10 months ago
Quoted from pinballphile:
I believe the post you are referring to works like a door stop for the hinged panel that houses the lamps. Without it, the door could hit the side edge of the backbox and break lamps or cause other damage. Normally, it should not come in contact with the translite like that, though.
#7 10 months ago
See 0geist0's post. I use Sprayway.
#8 10 months ago
Quoted from Betelgeuse:
This happens a LOT when operators don't latch the back door. Or if the door/panel latch is broken. In the 90s, this was very common.
#9 10 months ago
Purple Sparkle glass cleaner used here for years...
#10 10 months ago
Copy that---Target had some Sprayway so I'll give that a go. Appreciate all of the input. I'm glad to finally know what that post was for. Thanks again!
$ 88.99
