(Topic ID: 237125)
Advice on coils for bally loop the loop
By grandadpinball
5 years ago
#1 5 years ago
Hello, continuing to work away in strip and rebuild of my machine. trying to identify two coils I need to replace. 1 is the coil for HOLD and the 2nd is the coil for 2nd coin. none of these coils have markings and no reference to them on a document I have, called " Bally EM Pinball Coil Chart. If you can offer advice I would appreciate your help. One other question. The hold coil has a " resister" small Gray flat item with wire at either end. connected from one coil terminal to a blade with a Gray wire with red red tracer 91-3 on schematics. this seems to have got very hot at one time and may be burned out. Is this an original fit or has it been added to help load on coil? Thanks for your time and expertise. Pat
#2 5 years ago
Do you have a high quality scan of the schematic you can post?
#3 5 years ago
http://www.planetarypinball.com/reference/partsmanuals/BLY_Parts_1969/index.html#/45/zoomed
Looks like the Hold relay is part # c-7800-335 https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=C-7800-335
The 2'nd coin (same as 1'st & 3'rd coin ) chute # c-7800-384 https://www.marcospecialties.com/control/keywordsearch?SEARCH_STRING=C-7800-384
You would have to see the value of the resistor on the schematic but a fantastic post here about it & what it does https://pinside.com/pinball/forum/topic/what-is-this-4#post-3358932
#4 5 years ago
Quoted from currieddog:
Yes, OP, please post one. If you have the schematic you can get a high quality scan of it from (for example) Staples ($2) or Kinkos ($6)
#5 5 years ago
Quoted from chas10e:
Note that on this era of Bally flipper games, the hold relay is energized and the Tilt or slam switches literally short the hold relay hot wire to ground causing the relay to drop. It also causes one helluva spark when the switch is "made".
#6 5 years ago
Afternoon, thanks all for help on this I will arrange to purchase these, takes a few weeks as I'm in Scotland and I may raise another post as I'm concerned there is a fault somewhere in the start up sequence. For Currieddog, can I say the schematic I have is OK, I can read with good light and I could copy it for you. It would cost about £6.00 plus the cost of postage. Glad to help if you want one.
#7 5 years ago
Hello, You were right chas10e about the KKN 335 coil but as I do not have any relays for first/ third etc coin I cannot make a comparison. There are six relays that relate to starting and ending as follows-
END OF GAME READING 64.2 OHMS-------------PLAYER UP 91.4 OHMS-----------BALL RETURN 91.4 OHMS-----------HOLD 100 OHMS (KKN 335)---------
ANTI-CHEAT 9.5 OHMS-------------2ND COIN BROKEN. Do you think player up coil is the same as 2nd and do you have an opinion on the lower readings on end of game and anti-cheat? I have asked Marco specialties advice and the were good enoughto look at manuals etc but advised that the forum was best place for help. Praise indeed so thanks if you can help.
#8 5 years ago
I think the values listed are fine (except "broken" ) is "broken" a dead short or infinite resistance ?
The values for the 2 coils I linked above aren't listed in this chart: https://www.flippers.com/coil-resistance.html but you can see the values of other coils vary within those ranges
Quoted from grandadpinball:
I think the idea of seeing a full schematic scan was to help assist you and others with this machine. I don't know how they get submitted to the IPDB .... this one is for the "replay version" https://www.ipdb.org/machine.cgi?id=1475
"add-a-ball version" here ... this one does have a snippet of the alternative wiring: https://www.ipdb.org/machine.cgi?id=5279
#9 5 years ago
Thank you again for this information. It is all helping to widen my knowledge which I hope will help get this game going.
#10 5 years ago
Is your Loop the Loop the replay or addaball version?
#11 5 years ago
Hi thanks Howard, sorry been away few days. The machine is a free ball machine.
#12 5 years ago
A bit closer to home grandadpinball Pinballmania has some Loop the Loop docs listed on his website
https://pinparts.co.uk/p/manuals-and-schematics
#13 5 years ago
Hi @grandadpinball. Bally released two versions of this machine in Sep 66 - "Replay" and "Add a Ball". According to ipdb the AAB was exclusive to Italy so in Scotland you most likely have the Replay, but not impossible an AAB! I'm not sure if the Add a Ball is a true implementation as this machine precedes the conversion kit available from Rocket III in April 67, looking at the difference in parts it's probably some form of "Shoot Again". Apparently the AAB has a kicker instead of a special on the left outlane and a different backglass (by part number) which might help identify.
This machine interests me as it may be the first occurrence of the "rotary flipper", I have this too on my Rocket III.
More info here;
Replay version https://www.ipdb.org/machine.cgi?id=1475
AAB version https://www.ipdb.org/machine.cgi?id=5279
#14 5 years ago
Thanks a lot astyy, I got a schematic from pinballmania and found Andy very helpful. The Outlane on the left is a special with a kicker to put the ball back into play so it would appear from your info to be a AAB. I have just got round to fitting the damaged coils to the machine. I am trying to get the machine to work prior to rebuilding the play surface which is stripped of all parts except electo mechanical parts. Few problems though, the machine will only start by pushing the hold coil in. It will zero score reels and all lights will come on. spinner on playfield will work but nothing else on playfield will operate. The machine has never had a coin mechanism but would start with button on door and flipper on left. Will start working on this soon but any suggestions helpful.
This page was printed from https://pinside.com/pinball/forum/topic/advice-on-coils-for-bally-loop-the-loop and we tried optimising it for printing. Some page elements may have been deliberately hidden.
