So far I have just cleaned metal parts by hand using this product which I find excellent:
But I read some many posts on buffers, that I bought this today from HF. After the 20% coupon its dirt cheap for a fairly heavy tool. http://www.harborfreight.com/6-inch-buffer-94393.html
I tried it on a shooter rod and saw little difference. So I put some of the metal polish on the rod and then did it, and after a few repeats the rod looks great - but now my buffer wheel is all black. I did some reading and I think I may be doing this all wrong (black on wheel apparently is due to too much polish and now need to clean with rake/hack saw blade).
So now the stupid questions:
1. What do you guys do - just use the wheel, or add a little compound/metal cleaner/something?
2. Does a black wheel matter? And if so, should I just replace rather than messing around with rake?
Finally, and I'm sure this is a really stupid question:
3. When I use the metal paste manually, I am worried that if I keep going until it does not leave thick black on the cloth, that I may take the brass/chrome/finish off. For example, this coin plate (which I removed the paint someone had added) even though I have used the metal polish many many times, it still shows tarnish on the metal and the cloth is still thick black each time. Do I just keep going until no more black?
I searched the forums but could not find anything really to help, so as always, appreciate the group's input.
