(Topic ID: 238415)
Advice: Moving game walkout basement
By djsolzs
1 year ago
  • 22 posts
  • 14 Pinsiders participating
  • Latest reply 1 year ago by Electrocute
    #1 1 year ago
    Looking at buying a new house keeping my collection in mind. Some of the houses we have looked at have a small hill going down from driveway to walkout basement.
    What’s your strategy to move your games down and up? Anyone build a ramp of some sort or tracks? Just man up and walk the dolly up and down?
    Just curious if anyone has built anything to accommodate this.
    #2 1 year ago
    Hills are ok going down, but a pain going up. Especially if it's wet, muddy, snowy, or any other form of uncooperative weather.
    If you have a sidewalk, then that's usually ok, depending on the incline.
    #3 1 year ago
    Just invest in a dolly with nematic large tires and you'll have no issues. Just avoid the days it really muddy or you will be laying sod later. lol
    #4 1 year ago
    Just drive around and back it up to the door, problem solved.
    John
    #5 1 year ago
    I'm dealing with the same issue right now. I've been debating doing flagstone steps as the incline on my hill is quite steep.
    #6 1 year ago
    Quoted from djsolzs:
    I just roll with ours. Strap the game to the dolly and just take it slow. I bought the big wheeled blue dolly from harbor freight and that works great. If you have an extra pair of hands that makes it really easy.
    There is one local collector that built a sidewalk that runs from the back door of his basement all the way up to the driveway. His home was a new construction so easier to add to the plans.
    #7 1 year ago
    Quoted from Yelobird:
    This exactly nematic (air filled) tires. Dont use solid plastic wheels on grass and you will be fine.
    #8 1 year ago
    My hill is fairly steep and the route has a curve that slopes down and to the outside.
    From the vehicle - machine slides into a blanketed yard cart. Tractor it to the basement door, double wide . Slides from cart on to a HF lift-table. Position, jack up, legs on. One man operation. My dolly now only gets used on the 'away' side of the move.
    #9 1 year ago
    Here is a picture for reference. I cant get a vehicle back here - but I like the idea of the yard cart on a tractor. Do you have any issues going down the hill or do you strap to yard cart?
    I have moved plenty of games out of houses but its only one off so I was just looking for any creative ideas.
    #10 1 year ago
    That looks much easier than the route around the side of my house. Use a dolly with large, air filled tires and it shouldn't be bad. I have had one roll over wipeout (Doh!), but it was low speed and no harm was done. It also helps to remove the head to lighten things and improve the balance. Surprisingly, moving NIB games still in the box isn't bad. Either way, it helps to have a second person, mainly just to watch side to side balance and prevent roll overs.
    #11 1 year ago
    This is exactly the kind of grade I have. Get this. Probably same as the harbor frieght one.
    https://www.walmart.com/ip/700-lb-Capacity-Bigfoot-Hand-Truck/124330274?wmlspartner=wlpa&selectedSellerId=16440&adid=22222222228158747699&wl0=&wl1=g&wl2=m&wl3=269472551037&wl4=pla-447593693989&wl5=9014416&wl6=&wl7=&wl8=&wl9=pla&wl10=120813301&wl11=online&wl12=124330274&wl13=&veh=sem
    #13 1 year ago
    also, invest in a shipping blanket or two and a couple of ratchet straps. Wrap the game and strap it to the cart. My incline also has a side slope, and the game always wants to tip off the cart. Luckily I am a big guy and can hold it from rolling, but someone more of the norm might struggle keeping it upright.
    #14 1 year ago
    same approach here.
    #15 1 year ago
    Quoted from chuckwurt:
    that's the one I got, works like a charm!
    #16 1 year ago
    9264FEA8-B6CC-450B-B21A-FC3300DD5703 (resized).jpeg like $60 at harbor freight!
    #18 1 year ago
    I’m lost without that bad boy.
    So your saying you Loooveee your dolly Chuck? lol
    #19 1 year ago
    Sleeps in bed with me. Wife has to sleep on the floor.
    #20 1 year ago
    I need to make sure the load is towards the inside of the compound curve - usually just stuff a couple of HF moving blankets. If the load shifts while traversing the grade the weak tongue could potentially allow the cart to flip - just go slow or have the kids stand guard! Never have needed straps.
    I maybe should take the tiller and make a cut on the curve, add a rock wall and petunias-- but that means more work and less pinball!
    Cheers
    Tom
    #21 1 year ago
    Yeah I have a slightly steeper hill than that and have had no trouble moving pins in with just a large-air-filled-tires dolly. helps to have another person there to apply pressure if you start to tip but it has not been a problem for me.
    #22 1 year ago
    Looks like this would work great on uneven terrain. Just a bit expensive.
    304841D3-4175-4F76-A702-30CE394F39E8 (resized).pngEAFCE70D-7925-4FA9-8F22-667BD587B886 (resized).jpeg
    Back Alley Creations
    Metal-Mods
    $ 48.00
    $ 209.99
    $ 1,000.00
    Playfields
    Pinball Playfields
    Flashinstinct
    $ 159.95
    Pin Stadium Pinball LEDs
    £ 39.00
    PinballToys
    $ 40.00
    The Flipper Room
    $ 34.00
    The MOD Couple
    $ 9.95
    $ 12.95
    COINTAKER.COM
    $ 9.95
    $ 99.99
    $ 26.95
    $ 95.00
    Pinball Mod Co.
    $ 4.49
    $ 99.99
    $ 42.99
    Lee's Parts
    $ 24.00
    Pin Monk
    $ 5,999.00
    Arizona Pinball
    $ 54.99
