(Topic ID: 70353)
Advice for changing acrylic playfied on Elvis
By pinballpete
10 years ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 10 years ago by PinChicago
#1 10 years ago
I am wanting to shop out my Elvis and replace the acrylic upper playfield, but I can't figure out how to get it out for the swap. Do you have to disassemble the hotel? If so does anyone have any strategies for taking it apart? I am ok shopping older games, but with the moddern games I am always worried I won't remember how it all goes back together.
#2 10 years ago
I removed mine recently to flame polish and it now looks like new. I think I had to take two screws out of the sides of the hotel, and then the rest was easily accessible. I do remember that one bolt under the hotel was just a little bit tough to get the socket wrench on and I had to switch to a different socket that was a little bit thinner. It was nowhere near as bad as I thought it would be to get off.
You should not have to replace it unless you have deep gouges. Mine was really cloudy and full of fine scratches. I washed it using only dishsoap and my hands using warm water, then dried and flame polished it doing sections maybe 3" x 3" at a time and letting that section cool a few minutes before doing the next section. I got no warping and it cleaned up perfectly.
Good luck....it changes the looks of the entire game to clean that piece up.
#3 10 years ago
What he said ^^^^^^^^
#4 10 years ago
Thanks for the advice I will see if I can make some progress tonight.
3 months later
#5 10 years ago
I know that I am responding to an older post, but it may help someone
in the future with the same questions...
You do not have to remove the hotel.
Remove all the support screws that are obvious from above. There is one that
is a bit difficult to get to, especially to put the nut back on, but it
should be easy to find the 6 or so mounting screws. When the playfield is
loose it can be lifted on the left side and rotated out from under the hotel
and freed.
To remove the flipper bat, you need to go under the playfield and you
will see that the flipper shaft extends down through to a clamp and
the flipper coil mechanism. Loosen the nut on the clamp a bit and you
can free and remove the bat. Take notice as you do that there is a
tube spacer below a large plastic grommet that surrounds the bat at
the upper playfield. If you just work the bat loose all these pieces
will go sliding out but it's not hard to get everything back in
place. When you reassemble everything, unlike standard flippers there
is no alignment hole. Just position the flipper almost touching its
backstop on the playfield and tighten the clamp nut securely.
This advice was provided to me many years ago on rec.games.pinball
by Carl Lizza, and it was very helpful.
$ 17.50
$ 45.95
Playfield - Plastics
The Pinball Scientist
$ 18.95
€ 17.00
Pin-Decals
7,000
Seaside, OR
$ 17.00
Nordic Pinball Supply
7,000
Blackwood, NJ
€ 18.00
Pin-Decals
Sparky Pinball
Professor Pinball
+CY Universal
$ 12.95
6,500
Pittsburgh, PA
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/advice-for-changing-acrylic-playfied-on-elvis and we tried optimising it for printing. Some page elements may have been deliberately hidden.
