Hi Justmc16
in post-3 You +/- write "am a newbie" --- no problem - we do troubleshoot in small steps.
DANGER - electricity can kill You --- whenever You work in the pin or just look into the pin: HAVE the main power cord unpluggrd. ONLY plug-in (and start a game) when You need electricity for a test.
Have the main power cord unplugged - look at Your transformer - look at http://www.ipdb.org/showpic.pl?id=703&picno=41663&zoom=1 --- dominant the two yellowish-muddy-brownish wires called wire Yellow (this is the return side (common) to the transformer). Clip-on an Jumper-Wire at this transformer-lug "Yellow" and take the other end of the Jumper-Wire through the open Coin-Door out into the open --- the free end of the Jumper-Wire shall not touch metal.
Take an second Jumper-Wire --- look at the Coil on Your Number Match Unit --- one side has two wires of color-red soldered-on --- the other side has one wire of color-orange-red soldered-on. Do NOT proceed when You are not 100% sure You actually see wire-of-color-orange-yellow !!!
Clip-on the second Jumper-Wire at solder-lug orange-yellow and take the other end of the Jumper-wire out into the open --- NEAR the first Jumper-Wire --- NOT touching metal.
Plug-in the main power cord - start a game - when You can play: NOW grab the two Jumper-Wires at "insulation" - then tip together the free ends and pull apart --- big question: Does the Coil on the Number-Match-Unit fire and (hopefully) the Unit makes a step ? Write about.
Your picture in post-12 shows an Adjustment-Switch --- let it "as is".
We will come to "post-13, Bell".
I live in Switzerland (south of Germany) --- we are ahead in time to the USA about 8 to 10 hours. This might be the last post I write "today" - greetings Rolf
