I just started getting the Adjust Failure error on my Dr. Dude. After some searching around it seems that replacing the batteries usually clears this up. Here's where I'm at right now:
- Adjust Failure error popped up. Went through menu to reset factory and then everything worked fine
- When you power off the machine and then come back to it after a few hours, the Adjust Failure error is present again.
- No corrosion on old batteries or battery holder, everything is very clean.
- Replaced with 3 fresh AA batteries but the problem is still there.
- When you power on, it'll say adjust failure but then you can reset the factory settings and play as normal.
- If I power off the machine for 5 seconds and then turn it back on you can play as normal. If you wait 20 seconds or so, the Adjust Failure message pops up and you need to reset factory settings in order to play.
Any ideas?
