There seems to be a common issue on taxi, as it uses the older wire inlanes that the inlane ends a little bit too far away from the pivoting end of the flipper, causing the annoying ball hop due to the gap between inlane and flipper.
I've tried loosening the 8 hex screws on the flipper assembly, but there isn't really any play to adjust the thing closer to the wire on to (in order to close the gap). You can't really move the inlane either, as it is held in place with holes in the pf.
Has anyone addressed this? It's been a common issue with both of my taxis. Can't seem to fix it.
Anyone?
