So we have all seen this before: light on the Swamp in TAF, SOL hole in AFM, Rats or Mystery hole on BSD. I am attempting it on my AFM SOL hole.
Simple enough: a 555 light socket screwed to the underbody of the PF, one hex screw to hold it in place, wire and alligator clips to the socket to supply the power. Got it.
Here's my question(s) for those who have done it themselves - these scoops are pretty closed off assemblies with 4 welded walls allowing for what looks like minimal area for the light to shine through. If you have your playfield up and leaning back, where exactly are you mounting the light for maximum effect? Are you mounting on the side or directly in front of the scoop to allow light to hit the main body of the scoop? Are you using regular bulbs or special ones like the flex-head LEDs that can be twisted and moved around?
I'm am all about "DIY"ing; I just want to get this right the first time - hence my questions. Thanks everyone!
