(Topic ID: 148371)
How to Add LED Flashers to System 11 Games
By mrgregb123
8 years ago
There are 109 posts in this topic. You are on page 1 of 3.
#1 8 years ago
UPDATE: I am posting an "idiot's guide" on how to do this at the end of this post. It certainly works for Dr. Dude and -should- work for other System 11c games too.
When I hit the flippers on my Dr. Dude, about 5 of the flashers in the game pulse dimly for a brief moment. Not all the flashers, just 5 of them. All flashers in the game are LED.
I read that this is a known issue in System 11 games. The solution I found was to remove 4 diodes from the aux power board and add diodes to a few coils. I just need some clarification before I do this....
1) These diodes are the ones located on the power supply (top right) with the big heat sink, correct?
2) Does it matter if I clip them off or desolder them?
3) Are the diodes I removed from the power board the same ones I'm adding to the coils?
4) Does anyone know where the diodes go and on which coils on Dr. Dude? I found instructions for Whirlwind but obvious using different coils here.
Thanks guys!
EDIT:
OK - here's the idiot's guide to getting LED flashers to work properly on Dr. Dude and other System 11c games.......
1. Purchase 1N400x diodes on Amzn. The "x" can be any number. I used 1N4001 but the others work too. You can get 50 of these for $3 shipped. Good to have on hand.
2. Find the aux power board in the backbox. It's located near the middle of the right side, BELOW the power supply (power supply has large heatsink). Find the diodes labeled D3, D4, D6, and D7 (diode = small wire with the black thing in the middle) on the aux power board. They are all next to each other vertically. Use a wire cutter to completely remove those four diodes I just mentioned.
3. Now find coils 3, 4, 6, and 7 under your playfield. If you have no clue which those are, grab the manual for your game and find the solenoid table, usually found towards the beginning. In the table, you will see the Solenoid # (i.e. the coil #) and then the function describes what it is so you can identify it. In Dr. Dude, you want the Ray coil, Gab coil, drop target coil, and knocker coil (you can skip that one if you disconnected it).
4. Solder a 1N400x diode to each of the above coils, with the gray banded side of the diode attaching to the power wire lug (power wire is the thicker wire of the two attached) and the non-banded side attaching to the other lug.
5. Install your LED flashers, start a game, hit the flippers. No flashers should fire. There you go!
#2 8 years ago
This is what I found:
"This is what happens to all system 11B and 11C games (with the Aux driver board) when you install LED flashlamps into solenoid spots 3,4, 6 and 7.
There are tie-back diodes on the large TIP36 transistors that connect those circuits to the 50V power source. There is a some feedback into these circuits from the flippers that is not apparent until you install LED's.
To fix this, Cut diodes D3, D4, D6 and D7 from the aux driver board. Then add diodes onto the coils for solenoids 3,4,6 and 7 (banded end of the diode goes to the power wire)"
"I believe any of the 1N400X will work. I usually use the 1n4007's"
https://pinside.com/pinball/forum/topic/ww-tech-help-flippers-trigger-flashers
Seems pretty straight forward.
#3 8 years ago
Quoted from nerdygrrl:
I tried that on my Whirlwind, but I still had errant flashes. I ended up just putting incandescent flashers back in.
#4 8 years ago
Did you remove the warming resistors as well?
As long as the warming resistors remain in place you will have errant "flashes". Step one in installing LED flashers is to remove the warming resistors from the lamp boards.
#5 8 years ago
No, but from what I understand, games made after Big Guns do not have these.
#6 8 years ago
The incandescent bulbs when in the socket are less than 5 ohms and the circuit requires this resistance to be complete. LED's alone have too high of an impedance for the circuit to perform as designed. All you need to do is put a 1k or 100 ohm resistor across the socket terminals when using the LED bulb. That way the circuit is complete and only partial current is needed / shunt thru the LED (a diode). Increasing the resistance across the terminal will result in a higher LED brightness... but 1k is plenty
Of course, if you have warming resistors, remove them...
#7 8 years ago
Quoted from herg:
Derp, sorry brain malfunction. You are correct. Thus the diodes....
#8 8 years ago
Quoted from castlesteve:
So what you're saying is that the solution to this issue does not require you to remove the diodes from the aux power board, but rather just attach a 1k ohm resistor to the two terminals of the flasher itself? Has this been tested by anyone?
#10 8 years ago
Quoted from herg:
I see you cut one end of the diode, but it looks like in the pic you re-attached the cut end to the resistor?
#11 8 years ago
What's wrong with incandescent flashers?
#12 8 years ago
I recently put LED flashers in a BK2K. They work as long as there are only a few leds in the back glass with the rest incandescent. Try adding a few incandescents till they stop flashing. They will eat up the extra power surge.
#13 8 years ago
Quoted from dsuperbee:
They're actually new diodes, but you could also move them if the leads were long enough. Basically, they are not placed correctly to work as flyback diodes. Here's a marked up schematic to show what I moved.
Quoted from kbliznick:
modifying the board and coils will still allow you to put incandescents back in. This was just an error in placement by Williams.
Alternatively you can leave the diodes on the board and modify the board. If you look at the schematic you just need to move the unbanded end of the diode to the other side of the resistor that it connects to.
Be aware, though, this did not fix the errant flashing on my game.
#14 8 years ago
I did try the adding some incandescent flashers to the line trick, which did not work. While the incandescents do not light up when hitting the flippers, the remaining LEDs still do exactly as before. Would be willing to try the cut/add diodes thing except not sure it fixes the issue 100%?
#16 8 years ago
#17 8 years ago
Great, to hear. I have to do this to my SoF. I placed an order from Great Planes last week and am still waiting for the bits. I am glad it worked out for you. I wonder why Herg is still having issues on his.
#18 8 years ago
Better yet, I wonder why Herg hasn't engineered a solution, called it FlasherOCD, and added it to his stable of awesome LED boards.
#19 8 years ago
Good work and thank you for documenting it.
Just as a fwiw, I used full flashers in a Bugs Bunny Birthday Ball (sys 11c) with no issues, no changes, no cuts. It may be a 'system 11c only if you have the problem' type of fix.
#20 8 years ago
Sounds like your just moving the back emf snubber diodes closer to the source(the coil) instead of having it far away on the board. Do the ones on the board even have to come off??
#21 8 years ago
Quoted from CNKay:
Now that you mention it, no, they shouldn't have to.
2 months later
#22 8 years ago
Quoted from herg:
I just ran into this with my Rollergames. Can you explain how just putting diodes on the A side coils would solve the problem? I having trouble understanding how it would if it's the flippers causing the issue. I'd rather not modify any boards if I don't have to, but I could add some diodes to coils if needed.
#23 8 years ago
Problem solved!
#24 8 years ago
This problem intrigued me, so I decided to take a look at the circuit some more to see what is actually going on. I suspected that D3, D4, D6 and D7 where conducting and causing the transistors to activate momentarily. It appears that the game keeps the A/C select relay energized for most of the game unless it needs to fire an A side coil. Therefore, most of the time, you will have 25VDC on the anode side of the diodes, such as D7. Because, W3 is populated, you will also always have 50VDC on the cathode side of the diodes. Normally, when you don't flip, the diode is reverse-biased and it does not conduct. When I connected a scope to check what was going on, it was just as I suspected... Flipping caused the 50VDC to drop below 25VDC forward-biasing the diodes. They conducted, and in my case, I saw the 50VDC drop to 0VDC.
So, herg, the reason it didn't work for you, was because moving them to the other side of the resistors will basically do the same thing and activate the transistor. You would have to cut them out and put diodes on your coils to make it work.
But, I may have a better solution...
I checked the ripple on my 25VDC and 50VDC lines and I'm getting about 1V - 4V of ripple! I'm thinking that my caps need to be replaced. It's possible that once they are replaced, the 50VDC line will no longer drop below 25VDC and the diodes will not conduct solving the problem.
Now, I'm no electrical engineer, but I do like this stuff, so please feel fee to comment away... tell me that I'm on to something or that I don't know what I'm talking about... I like learning from my mistakes.
PS: Anyone know if there is a System 11 schematic manual like Williams did for WPC?
#25 8 years ago
Quoted from steve1515:
Just kidding, but I was thinking that the cap on the flipper board may also need replacing. You should give this a try and let us know the results.
#26 8 years ago
We think alike... The game I'm working with is a Rollergames (System 11C) which doesn't have a flipper board. They moved those to the Aux Driver board which is the one that I'm starting with. I'm about to place an order for some caps. I'll post back on how it goes.
#27 8 years ago
Yea I miss spoke on that, but was meaning that C1, C3 need to also be replaced when you change C5 and C6. Should be very interesting results. Maybe a small improvement in flipper power?
#28 8 years ago
Quoted from GRUMPY:
I hope so. I've also been having what could be a flipper power problem. Should be an easy fix... only 4 caps on this board.
#29 8 years ago
I finally got my head wrapped around this, and you are right.
I had myself convinced that the diode on the board was the same as on the coil, and it would be except the power lug of the coil is disconnected from 50V when the C side is selected. You have to remove the diode to remove the path from 25V, through the flasher, through the diode, to the sagging 50V. Then, you have to add the diode back to the coil to snub the voltage spikes when those are turned off.
I hate to pull the diodes off the board, however, since if anyone is working on the game down the road and looks up info that says the coils in these games don't need diodes, they might end up pulling them off of there. I'm going to look into connecting them to the A side 50V after the relay. It might end up being too much of a hack, though.
As for keeping the 50V above 25V, I suspect you may have a tough time. Those caps are a very small value relative to the current that is drawn when the coils fire.
#30 8 years ago
Quoted from herg:
I was thinking this too, but since I have so much ripple, I think it's best to replace those caps anyway. Looking at the soldering on the bottom of the board, they look original, so it's time to replace. I think I'll eventually do the main power board also, but interesting thing is that my 5V line was rock solid, so I'm holding off on that board for now.
#31 8 years ago
5V is regulated, so as long as it's input stays high enough, you won't see any ripple on it.
#32 8 years ago
Do ALL system 11s need modifications done to use LED flashers?
#33 8 years ago
Quoted from Blackbeard:
According to what was said above, it looks like just the ones that were made prior to big guns. And even then, only if you are actually experiencing the described symptoms.
#34 8 years ago
Quoted from herg:
Well, now that you say that... it's obvious.
Quoted from ForceFlow:
I believe that Rollergames (my game) was after Big Guns, so I think there is a chance that you might see this problem with later System 11s that use this Aux Driver board configuration.
#35 8 years ago
I'm going to order some flashers from comet today for my mousin around. I'll report back what my findings are.
BTW: if I do indeed have issues, what would they be? Flashers just not working? or going off at bizarre times?
#36 8 years ago
Flickering (not a full flash) at "bizarre" times. More specifically, when coils fire.
#37 8 years ago
Quoted from mrgregb123:
#38 8 years ago
What I notice is that when either flipper button is pressed to energize the flipper, there is a momentary pulse/flash of the flashers 3C, 4C, 6C and 7C. The actual count of flashers depends on the game. It's always 3C, 4C, 6C and 7C in both my Rollergames and Black Knight 2000. I saw this in my Whirlwind when I first put LEDs in that and didn't know why. I put incandescents back in those flashers.
So it sounds like the solution (other than putting in incandescents) is:
Remove D3, D4, D6 and D7 from the auxiliary driver board (or at least take it out of circuit - remove one leg).
Install coil diodes across 3A, 4A, 6A and 7A. There's no easy way to do this on the auxiliary driver board without it looking like a hack.
Can someone with much more electrical knowledge than me confirm that removing D3, D4, D6 and D7 *IS* required? I tried putting a single coil diode across a coil without removing the board diodes but it didn't help. With my limited understanding of the above discussion this seems to make sense (i.e. must remove the diodes off the board).
#39 8 years ago
Bump for more info.
#40 8 years ago
Quoted from DumbAss:
Yes, the way the circuit is, it would be required. There is a way to make it work on the board, but it would look like a hack.
You can wait and see if replacing the caps on my board works and then try that instead. If it works it will not be a hack and will be much cleaner. I'll post back once I get the caps and try it. I expect to have time to do it this weekend.
--Steve
#41 8 years ago
Following this thread with interest. I have just retro-fitted flashers to the insert board of my Rollergames and fitted LED's. They are basically lighting up like a Christmas tree when they should be off. Putting the odd incandescent back in helps but I will definitely be doing the moving of the diodes off the aux driver board and onto the 50v coils.
Strangely, different LEDs exhibit different ghosting behaviour.
#42 8 years ago
Quoted from Andy_B:
I'm not surprised. Not only can LED voltage & current requirements vary greatly between manufacturers, did you know they can also vary depending on color?
#43 8 years ago
Well, the results are in... I've replaced the 4 capacitors on the Aux driver board, but I don't see much change. Is it possible that Williams designed a board with this much ripple?
Here are some scope images of the waveforms...
50VDC Before
50VDC Before50VDC Before
50VDC After
50VDC After50VDC After
25VDC Before
25VDC Before25VDC Before
25VDC After
25VDC After25VDC After
The new caps reduced the ripple by a small amount, but nothing significant. And, if you look at the waveform below of when I hold a flipper button, you can see that there is about 33V of ripple on the 50VDC line!
Do you guys think this is normal for a System 11 game?
50VDC While Holding Flipper
50VDC While Holding Flipper50VDC While Holding Flipper
#44 8 years ago
Do you think the bridge retifier is on the way out?
#45 8 years ago
I'd say that looks about like what I'd expect. From what I remember, you only have about 200uF on the 50V. By comparison, I put 20000uF on the GI OCD, and there is still a bit of ripple on it at high load. GI lighting is a small load compared to flipper coils.
#46 8 years ago
I don't think the bridge is out because the wave shape looks correct, it's just that there isn't enough capacitance.
I guess I'll just install a few incandescent bulbs to get rid of the blink. (I'd prefer not to modify my board.)
It was a cool experiment though.
I hope the information gathered was useful.
#47 8 years ago
Sorry. More stupid questions. I don't understand electronics too well.
Is this situation like the controlled lamp matrix "ghosting" phenomenon? I understand that is solved by putting a capacitor on the LED to absorb the stray voltage/current.
Can a similar thing be done here with the flashers?
If so ... what kind of capacitor and what voltage and Farad rating?
Is it a one rating capacitor size fits all regardless of the number of flashers on the circuit?
Or will it vary depending on the number of flashers?
Is it possible to just put it across the positive and negative wires that connect to the auxiliary power driver board as a (central) choke point rather than across each (peripheral) flasher socket?
#48 8 years ago
No, I don't think adding capacitors in this way will work. If you want to have LED flashers in those 4 positions that cause blinking, then you would have to remove the 4 diodes from the aux power board (or one side of them) and then add diodes across the A-side coils. This should work.
In my case, I just don't like removing things from boards because I don't want someone in the future to wonder what I was doing.
#49 8 years ago
Last night I cut off the non-banded side of D6 and put a diode across solenoid 6A. The flashes did indeed go away for flashers 6C. So this works if you're prepared to modify your auxiliary driver board.
Two questions arise. Again ... please forgive my electronics ignorance.
1) Can I attach a diode across 5J-11/12 to 5J4-4 and achieve the same result as the diode across the coil for solenoid 6A? If so I assume this can be done for 5J4-7/6/2 for solenoids 3A, 4A and 7A.
2) What is/was the way to make it work on the board that you mention in post #40?
#50 8 years ago
1.) If when you said "5J-11/12" you actually meant "5J12-11/12", then yes, that should give you the same results.
2.) Yes, doing something like this was what I was thinking. Basically as long as the anode side of D6 is connected to the anode side of D39, it should work. (Same for the others.)
Hope this helps.
$ 95.00
Pinball Mod Co.
$ 22.50
Magazines/books
Pinball Magazine
$ 29.99
Gulf Shores, AL
$ 80.00
Listowel Pinball
$ 18.95
2,400 (Firm)
Carpentersville, IL
$ 27.95
$ 27.00
3,750 (OBO)
Jesup, GA
$ 5.95
The Pinball Scientist
4,200 (Firm)
Phoenix, AZ
Great pinball charity
Pinball Edu
This page was printed from https://pinside.com/pinball/forum/topic/adding-led-flashers-to-system-11-games and we tried optimising it for printing. Some page elements may have been deliberately hidden.
