(Topic ID: 227218)
Adding a 2nd speaker to Sega games
By lowndes8
6 months ago
  • 10 posts
  • 3 Pinsiders participating
  • Latest reply 6 months ago by HighVoltage
#1 6 months ago
I have a Sega space jam and want to add a 2nd speaker to it seeing sega were too cheap to add one
Im going to buy a set of cheap 4" 4ohm car speakers. Now to i just wire the + and - to the existing speaker?
As i read this
"The Sega amps are only 4 ohm capable. If you are using standard car audio 4 ohm speakers, these need to be wired in series. Do not just run the wires also over to the new speaker. If you do that you will be putting too much strain and heat on the audio amp and will blow it eventually if not soon. The proper way to wire these in series would be to desolder and move the - wire from the original speaker to the - on the new speaker. Then run a new wire from the - on the original to the + on the new speaker. Now everything is wired safely."
So wanted to make sure i wire it right so i dont blow the amp. Any help would be awesome
#2 6 months ago
So these two images which one is right?
#3 6 months ago
Not something I've done on a pinball machine (so perhaps take this with a grain of salt [I have done many car/home stereo installs]), but from what you mention, I would use two 8-ohm speakers and wire them in parallel (like #1). That should offer better power from the amp than two 4-ohm speakers wired in series. Two 8-ohm in parallel gives you 4-ohms, while two 4-ohm in series would be 8-ohms (the lower the ohms, the more wattage you'll get from the amp, but as you note, not all amps can handle that). As I expect the audio is mono anyway, I'm not sure if it could potentially be better to fit a slightly larger, single speaker instead at 4-ohms?
#4 6 months ago
Neither of your images is correct. On first speaker you want in to + and then the out from - to + of second speaker and out from - of second speaker back to board. See image below. You can do what Medisinyl says too, but I actually prefer the series wiring. There's plenty of power to the backbox anyways, so increasing the ohms actually creates a more pleasant balance with the cabinet speaker with more bass. You could and should also find a high-sensitivity 4-ohm subwoofer for the cab and put a low-pass filter on it to complete the effect.
I did it on my X Files and it sounds amazing.
#5 6 months ago
Thanks guys i need to use a 4ohm speaker as it has 4ohm stock
#6 6 months ago
Quoted from lowndes8:
Thanks giys i need to use a 4ohm speaker as thats what is already in there
I'm saying that two 8-ohm speakers IS a 4-ohm speaker (in parallel), which would be optimal if you must use two speakers. Two 4-ohm speakers will result in either 2-ohm (parallel) or 8-ohm (series). 2-ohm possibly doing damage, and 8-ohm drawing less wattage from the amp.
#7 6 months ago
Quoted from Medisinyl:
Right i get what your saying now. Makes sense as i looked at my south park and it has 2 8ohms speakers wired in parallel.
I think the hard part will be finding 8ohm speakers
#8 6 months ago
Edited post, see above ^^^
#9 6 months ago
Right i get what your saying now. Makes sense as i looked at my souther park and it have 2 8ohms speakers wired in parallel.
While two 8-ohm would work as I noted, it sounds like HighVoltage knows more about your specific application, so you've got options
#10 6 months ago
Just FYI, both of your images are parallel wiring, the second one you're just making the second speaker out-of-phase. Stern seems to do that or used to on some of their machines. Some say it is for a pseudo-surround effect, others say it's just a dumb mistake.
PinSound
Gweem's Mods
Greenville, SC
$ 29.95
$ 2.00
Doc's Pinball Shop
$ 89.99
$ 24.99
Lee's Parts
$ 29.99
$ 48.00
$ 29.50
Playfield - Plastics
Bright Lights Pinball
$ 48.00
$ 0.35
Gameroom Mods
$ 49.99
$ 7,995.00
Classic Game Rooms
liorillusion
Yorktown Parts and Equip
