Well I should say I finished adding them tonight. I started right after TPF when Melissa at Cointaker hooked me up with a great price on all of them! It took many hours to get them all installed and I'm quite pleased with the results. I still have to drop the PF back in and get a pic of all the GI and inserts lit up at once, but it's gonna look good.
I made about a dozen little custom wiring harnesses like this.
Each one just drops into the nearest hole in the PF and gets routed underneath to power.
I wanted it to be tidy and easily reversible.
This distribution block started out as a temp fix to get them powered. I'll probably just put wire terminals on the wires and leave it in place. From here they will be powered by an independent 12v switched power supply.
Hope you like!
