(Topic ID: 263727)
Addams: weird behavior on startup - seen this before?
By Bospins
1 year ago
  • 17 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by mbwalker
    #1 1 year ago
    I was finishing up my led conversion and installation of color dmd and led ocd boards.
    Machine was working great, then I noticed the color dmd went out. Strange...looked and saw the 12v secondary fuse blew. (F116)
    Replaced it, then I got this wacky behavior on startup...see video:
    I did the basic stuff, visually checking fuses, reseating connectors...all fuses seemed ok (although I didn’t check continuity with my dmm). No change.
    I have done zero board work. I replaced U18 with a fresh ROM from Matt because it was causing an error on startup, which cleared once it was replaced. The replaced chip was an EEPROM.
    U6 is also an EEPROM. I have a replacement from Matt. Could it be this would fix it?
    Just checking here first for any bright ideas because I don’t want to fry any chips.
    A basic shot of the backbox inside is below...its busy at the bottom because of the 2 Ocd boards. Game was playing great for a dozen games or more with this configuration.
    #2 1 year ago
    Your going to have to recheck all your work, and meter your fuses...check 12VUR fuse first. I'm thinking you already knew this would be the first response.
    #3 1 year ago
    Looks little your CPU isn’t booting, check that U6 is inserted correctly for orientation and that all pins are in properly.
    #4 1 year ago
    Pin_Guy of course I made one mod at a time and played multiple games after each mod, and didn’t have any issues until this one. I’m hoping I don’t have to undo that work but of course I will if it comes to that.
    jchristian11 i suspect the cpu as well, especially since the other replacement chip went bad. But I don’t want to fry the replacement so wanted to check here if that was the likely cause first before blindly replacing parts.
    The cpu board itself is a rotten dog and looks in great shape.
    #5 1 year ago
    This rings a bell, at least with regards to the fuse blowing, not so much with the odd behavior. Make sure you don't have any extra accessories attached to the 12V line. I had a JD with a bunch of extra lights and the fuse also blew on mine after installing the colorDMD (LCD). I also ran the eeproms from Matt (btw, great seller) without issues, albeit a JD not AF.
    Got a meter to start checking power supply voltages?
    #6 1 year ago
    Hm...I have 2 led strips on that 12v line. Guess I’ll remove those
    ...and replace U6 and hope for the best
    #7 1 year ago
    Quoted from Bospins:
    ahhh good call.
    DO you have a Khar board on your CPU?
    #8 1 year ago
    No khar board.
    Replaced U6, removed light strips from 12v...no change.
    I am out of my depth but sure to learn something!
    #9 1 year ago
    Cool, I love that kind of attitude!
    Would you mind taking a video of the backbox boards when you power on the machine so I can see what its doing?
    #10 1 year ago
    No khar board.
    Just fix one thing at a time (i.e. the 12V load)! You'll get there, lots of good help around these neck of the woods.
    #11 1 year ago
    A little progress...removing j601 has the machine *almost* go into attract mode...the dmd is still scrambled (as it should be I think) but the controlled and GI lamps come to life, and the thing / bookcase cycle as expected.
    #12 1 year ago
    Well, are you all ready for a supremely unsatisfying conclusion?
    After my j601 discovery I decided to clean the pins with deoxit and reseat the cable a few times. In fact I did that with all the cables.
    Machine is working as expected now.
    My bookcase optos are not registering but I know that is an issue with the wiring harness because when I unplug and replug it works for awhile.
    Well that was a fun 2 hours!
    #13 1 year ago
    What's an OCD board?
    Obviously, I'd focus on anything you touched during the install if it was working prior.
    Edit: Oops, you just fixed it!
    #14 1 year ago
    You get to play with all your new toys now
    #16 1 year ago
    Quoted from Pin_Guy:
    This is what life is all about isn’t it?
    #17 1 year ago
