I am having a recurring nightmare of an issue with my Addams Family lower right flipper. The symptoms are that it will lock in the up position in game mode. It appears to just be the holding current windings and not the strong current windings that remain energized.
So far, I have:
- replaced the coil
- replaced both diodes on the coil
- swapped a Fliptronics II board in
- replaced all of the transistors for the lower right flipper on the Fliptronics I board
- verified all the resistors and diodes for the lower right flipper on the Fliptronics I board
- verified the EOS switch
The last one is where I started to tear my hair out. When I put the game into switch test mode, the flippers all work 100%. They flip and return as expected. If I put the game into game mode, the lower right flipper locks up on the first press of the flipper button.
When I have swapped Fliptronics II boards in, it has almost always worked for a while. Then the stick up occurs again. When I swap the original Fliptronics I board back in, it almost always works for a while. I have checked and all the connectors are good. No broken wires. Switch test looks good.
If anyone has ever seen this and wants to share the fix, I would be most appreciative. I am about to the end of patience with this issue.
Thanks,
ken
