Hey guys need some help. My addams family cloud topper light will not come on. Can u tell me what J connectors the two wires go too. I have replaced the bulbs, checked wiring but still cant figure it out. Thanks!
A few thoughts. They are #906 bulbs, you have them in there ? Check them in flasher test ?
Now in flasher test stop on cloud flashers, hit the start button and then keep hitting the + diagnostic button. This will step you though flasher, transistor, fuse, wire colors, and connector info - which one and which pin.
Hey LTG. There is brand new #906 bulbs installed. I checked them in test menu. They do not work. I also checked the wiring to the sockets. I checked J126 and J107. All look good. Even checked fuse 111. Everything good. . This is bugging the crap out of me.
Hey Skyemont - next up check continuity of wiring from connector to the sockets. May as well check bulbs too, even if new.
Or ground the metal tab of the transistor driving them, if they fire then you know wiring and sockets and bulbs are good, and transistor or back the other way is bad. If they don't fire then you have a break from transistor legs to bulb.
Ok, I'm going to revieve this thread from 5 years ago as I have same issue and cannot figure it out. The power flasher and cloud flasher are on the same circuit. Power flasher works in test but cloud doesn't. 111 fuse is good. Q30 transistor grounded only fires power flasher. Have continuity between J126-6, J125-7, J107-6, J106-5 and the light sockets in the cloud and back down to Q30. So what the heck am I missing?
This page was printed from https://pinside.com/pinball/forum/topic/addams-family-topper-light-issue and we tried optimising it for printing. Some page elements may have been deliberately hidden.
