Quoted from Shredder565:Spent some time fiddling with wires, moving switches around to see if they worked out of place. no such luck.
Just to start fresh, I have an extra set of the non working ones ready to be on order for tomorrow along with a new set of diodes (hopefully the right diodes) as a last resort to get 'em all working fast. If I'm going to have to cut and re solder wires anyway, might as well start with a fret set of prongs.
will give one last try of working with the ones tomorrow and see what happens.
BTW, now that my start button is working, how do the flipper cabinet switches get wired? Added some credits, and hoped to start a game just to get background music going, and got 'missing pinbal'. doh .
I doubt that the switches are bad, they are quite robust and easily checked with an ohmmeter.
More likely you have reversed diodes and/or reversed/incorrectly placed wires.
The correct diodes are IN4001, but most people put in the much more robust IN4007 ones.
Either will work perfectly.
Start reading here:
http://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Switch_Matrix_Problems
You can trace the wires back to the connectors by color etc. or from the row and column connectors to the end points.
If the wire pairs are right, you can even briefly touch the ends together (make a switch jumper out of a couple alligator clips and a piece of scrap wire and clip onto a diode (banded side away from the clip) connect the empty clip to the white wire and touch diode lead to the other colored wire) to see the wires work properly in test.
You will also see that the matrix everyone talks about is real and is represented on the display screen.
one of the 8 pins on the row connector go to one each of the 8 pins on the column connector, there are 8 pins on each connector, 8 x 8 = 64 switch combinations
Rows and columns now begin to make sense in a real world experiment (they are labeled on the cpu board).
Playing with the cpu board and jumpers is fun and informative. Its low voltge and if you take care not to cross something with high voltage, relatively safe.
Now you have learned how to test the CPU pins, and then the wires for continuity.
All thats left is to wire the switch correctly.
It should help to light your way.
The lamp matrix is similar in concept.
