New! Dark mode!
(Topic ID: 257696)
Addams Family - Scratch Build?
By Shredder565
11 months ago
  • 1,616 posts
  • 138 Pinsiders participating
  • Latest reply 17 minutes ago by Davi
  • Topic is favorited by 92 Pinsiders
Topic poll
“This project is”
  • Ambitious 77 votes
    44%
  • insane 81 votes
    46%
  • will be undone by a official remake in a few months..:) 18 votes
    10%
(176 votes)
There have been 284 images uploaded to this topic. (View topic image gallery).
There are 1616 posts in this topic. You are on page 19 of 33.
#901 7 months ago
Quoted from Shredder565:
I'm rather proud of getting that on the first try.
how does that look? deep enough?[quoted image]
A friend of mine showed me a drumstick is the proper height. Probably not exact, but it's worked for me every time. I have a couple scraps of cut up drumstick in my tool bag and use them as a guide.
#902 7 months ago
Use a small piece of 1/2" mdf below it, tap it down til snug, remove mdf. Also protects u from hitting pf with hammer.
#903 7 months ago
The center line of a ball should be even with the center line of the ball guide
#904 7 months ago
Go to 4:45 in this video and you'll see how Data East did it at the factory. Pretty easy method.
#905 7 months ago
Quoted from pinballinreno:
I was going to celebrate the last part being bought as the three balls needed .
#906 7 months ago
Read vids guide on re-populating playfield.
Just make the wire ball guides.
Cheap and easy.
Marco sells the perfect bender for $7
#907 7 months ago
My Break has arrived . Now, do I try an easy one....or not .
#908 7 months ago
Quoted from shirkle:
hmm, that would be the easiest way to judge I guess. but man, that floating head is distressingly creepy ;o)
#909 7 months ago
slight new problem. my grandfathers old reliable 50 year vice is a tad too small to reliably attach. the break wobbles to much. need a new vice it'll fit.
may have to add t his to the list.
amazon.com link »
Also, light boards ordered.
$50 total.
#910 6 months ago
amazon.com link »
$50 total.
Hmmm, light boards. Where did you order those from?
#911 6 months ago
Quoted from centre-drain:
the WPC facebook page. i will have to populate them myself.
#912 6 months ago
WPC Facebook page? I couldn't find it....
#913 6 months ago
cool thanks for that, I don't do facebook. One day when it's super uncool to join, I will.
have a lead on the boards though, thanks.
#914 6 months ago
last time I tried that trick, i blew out the bottom of a playfield by going too deep.
#915 6 months ago
Quoted from slicknick13:
The holes are supposed to be drilled all the way through the playfield.
Top quarter of the hole slightly larger than the wire, the bottom half of the hole slightly smaller than the wire.
Use the drill box holes/guides to size the bits. Or lay the bits down next to the wire and check with a straight edge.
Hammer in using 1/2" MDF as a spacer. This gives you close to the exact height of 17/32" to the center
Glued in with titebond III.
Removal is easy with a small drift from the bottom.
#916 6 months ago
light boards should be here by Monday. Ordering the new Vice as well. hopefully I can get a test one bent next week.
That feeling you get when you spend 60 tries and almost 60 hours trying to beat trial of the sword 3.... frig yeah!
only I didn't say frig!
#917 6 months ago
Putting in one last order today.
the four flipper sets I need.
the three magnet coils for the power.
and 1" Square Blue Rubber Pad With Adhesive Backing I can't remember what part needed it, but I know it was needed...
$257. that'll be it for a week or two.
Then I will order some CPU boards from a member here. and that should wrap up May orders.
I'm hoping by then my cabinet will be closer to shipping ;o)
Williams/Bally Magnet Coil 20-9247
SKU: 20-9247_coil
⋮ SAVE TO WISH LIST
Williams/Bally Magnet Coil 20-9247 Quantity
Quantity
3
$29.95
$89.85
1
SKU: 23-6629
1" Square Blue Rubber Pad With Adhesive Backing Quantity
Quantity
1
$1.50
$1.50
Full Flipper Assembly For Williams/Bally Machines From 02/1992 To 10/1998
SKU: a-15205-r-2_a-15205-l-2
Choose A Base Plate: Left
Choose A Coil: FL-15411
Choose A Coil Stop: A-12111
$0.80
Choose An EOS Switch: SW-1A-194 Normally Open EOS
⋮ SAVE TO WISH LIST
Full Flipper Assembly For Williams/Bally Machines From 02/1992 To 10/1998 Quantity
Quantity
1
$39.95
$40.75
Choose A Coil: FL-11753
$0.80
⋮ SAVE TO WISH LIST
Quantity
1
$39.95
$40.75
Choose A Base Plate: Right
Choose A Coil: FL-11630
$0.80
⋮ SAVE TO WISH LIST
Quantity
1
$39.95
$40.75
$0.80
Quantity
1
#918 6 months ago
What is the WPC group your were mentioning on facebook?
#920 6 months ago
Link doesn't work, must be a group you have to join.
#921 6 months ago
Quoted from Kawydud:
Send a message to wallybgood and he'll help you.
#922 6 months ago
I believe its invite only.
#923 6 months ago
Quoted from ThatOneDude:
Thank you!
#924 6 months ago
anyone have any documentation on how to wire my new light boards properly? that could be a project for this week. shouldn't be harder than the 100 solders I had to do for R2.
#925 6 months ago
Wire them? Are you talking about just soldering the header pins to the boards? Should be straight fwd, the boards should have empty holes and that should tell you how many pins you should be soldering to each..
#926 6 months ago
having never seene one of these in person, not sure what's involved just yet. but it would be nice to have an idea ;o)
Someoen asked about this a while back. I lost my original so had to re compile it. This SHOULD be everything. If it is, Total cost is currently around $5,950, barring AUS conversion rate on some prices. everything ordered to date, and from where.
virtual PinBall
Cabinet $1,599.95
Classic Playfields
Mirrored backglass
269.00
Gold Playfield $1095
Transformer
$450
Jeff wetzel pcb light
$50
Mr.Pinball AU
Side Art
$350
Pinball Life
Magnet Coils X3 Williams/Bally Magnet Coil 20-9247 X3
$89.85
Flippers X3
SKU: 23-6629
$1.50
$40 X4
$285.00
Action Pinball amusements
Family Gold Target Switch setup
$98.89
Planetary Pinball
Bookcase Cover 03-8621 Addams Family Pending 1 $6.00 $6.00
reorder Addams Family Thing Hand NOT DECORATED Pending 1 $40.00 $40.00
reorder Addams Family Playfield Plastic Set 31-1664-COMP (41 Pc) - IPB Pending 1 $169.00 $169.00
Shipping: FedEx 2 Day: $53.48
Sales Tax: $0.00
Total: $268.48
Pinball spare parts AU
The Addams Family Cloud Topper - with decals
03-8643 AU$130.00
Ordered: 1
AU$130.00
Wire ball guide 3
12-6466-12 AU$1.00
Ordered: 1
AU$1.00
Grand Total AU$227.51
marco specialties grand total $1447.14
Wire ball guide rail 1-1/4" 12-6466-5 1 $1.99 $1.99
Guide - ball trough return runway 01-3569-1 1 $19.00 $19.00
Magnet bracket and pole piece assembly A-15257 3 $16.95 $11.95 $35.85
Machine Screw 1/4-20 x 1/2" p-ph-sems 4020-01003-08 2 $0.45 $0.90
ADDAMS FAMILY (Bally) Hand bracket A-15303 1 $28.95 $28.95
ADDAMS FAMILY (Bally) Motor Thing 14-7966 1 $299.00 $299.00
ADDAMS FAMILY (Bally) Motor bracket 01-10561 1 $14.99 $14.99
ADDAMS FAMILY (Bally) Magnet core 02-4603 1 $10.95 $10.95
Machine Screw 6-32 x 1/4" p-ph 4006-01005-04 2 $0.11 $0.22
ADDAMS FAMILY (Bally) Bracket - anti trap 01-10655 1 $22.99 $22.99
Machine Screw 1/4-20 x 1/2" p-ph-sems 4020-01003-08 1 $0.45 $0.45
Washer .205 x 1.00 x .055 inch 4700-00130-00 1 $0.29 $0.29
Machine Screw 10-32 x 5/8" sl-bnd-hd-brass 4010-01062-10 1 $0.39 $0.28 $0.28
ADDAMS FAMILY (Bally) Hand cable H-15228 1 $12.00 $12.00
ADDAMS FAMILY (Bally) Opto board A-15285 1 $29.95 $29.95
ADDAMS FAMILY (Bally) Interrupter assy A-15310 1 $12.25 $12.25
ADDAMS FAMILY (Bally) Thing lower box A-14703 1 $79.00 $79.00
Switch subminiature with bracket A-11680 2 $8.95 $17.90
Rubber ring - White 27/64 inch or 7/16 inch OD 38-2764 4 $0.25 $1.00
ADDAMS FAMILY (Bally) Metal ball guide left 01-10591-L 1 $9.25 $9.25
Ball guide - long runway 01-10599 1 $18.00 $18.00
ADDAMS FAMILY (Bally) subway chute assy A-15070 1 $59.00 $59.00
Sheet Metal Screw #6 x 1-1/4 inch p-flh-a 4106-01042-20 15 $0.21 $3.15
Machine Screw 8-32 x 1/2" p-ph-s 4008-01157-08 1 $0.20 $0.20
Washer .187 x .625 x .059 inch #8 4700-00070-00 2 $0.25 $0.50
ADDAMS FAMILY (Bally) Bookcase cable H-15227 1 $12.00 $0.00 $0.00
ADDAMS FAMILY (Bally) Ramp main PR007 1 $219.00 $219.00
Locking nut - plastic 03-8363-1 1 $3.95 $3.95
Flange bearing 20-9610 2 $1.50 $3.00
Flange - plastic 03-8347 1 $10.95 $10.95
Shaft 1/4 x 2-9/64 inches 02-4418 1 $2.00 $0.00 $0.00
Adjusting screw Bally 02-4419 1 $15.50 $15.50
ADDAMS FAMILY (Bally) Bookcase lens 03-8624 4 $3.95 $0.00 $0.00
Washer 0.125 x 0.281 x .032 inch 4700-00003-00 2 $0.19 $0.38
Rivet - 1/8 x 1/4 inches nickel 07-6688-20N 2 $0.15 $0.30
ADDAMS FAMILY (Bally) Plastic 31-1664-25 1 $5.99 $5.99
ADDAMS FAMILY (Bally) Bookcase top blue 03-8621 1 $6.95 $0.00 $0.00
ADDAMS FAMILY (Bally) Bookcase frame blue 03-8622 1 $7.95 $7.95
ADDAMS FAMILY (Bally) Bookcase Base Blue 03-8623 1 $14.99 $14.99
Sheet Metal Screw #6 x 3/8" p-ph 4106-01004-06 2 $0.15 $0.30
Cable clamp holder 1/4" diameter 03-7655-4 2 $0.29 $0.58
ADDAMS FAMILY (Bally) Bookcase opto board set A-15017-18 1 $37.95 $0.00 $0.00
Nut 8-32 esn stop nut 4408-01119-00 5 $0.15 $0.75
ADDAMS FAMILY (Bally) Electric Chair 03-8647 1 $27.95 $27.95
Mini-post 8-32 thread 02-4003 2 $2.35 $4.70
Rivet - 1/8 sft D x 3/16 sft L x 7/32 Head A 07-6688-18N 4 $0.25 $1.00
Roll pin 3/32" x 5/8" 20A-8716-2 20-8716-2 1 $0.20 $0.20
Sheet Metal Screw #8 x 7/8" p-th-type 25 4108-01031-14 2 $0.24 $0.48
Crank arm - large 03-8620 1 $7.95 $7.95
Crank arm - small 03-8619 1 $6.99 $6.99
Machine Screw 8-32 x 5/8 inch p-ph 4008-01005-10 4 $0.15 $0.60
Washer .187 x .437 x .053 inch #8 SAE 4700-00016-00 5 $0.10 $0.08 $0.40
Machine Screw 2-56 x 7/16 inch p-ph-s 4002-01105-07 4 $0.28 $1.12
Twin nut plate dual 2-56 screw 01-8240 2 $2.00 $4.00
Diode - 400 volts 1 amp XO-254 1N4004 2 $0.19 $0.38
Switch sub-mini assembly 5647-12693-08 2 $3.59 $7.18
ADDAMS FAMILY (Bally) Bracket switch 01-10399 2 $1.55 $3.10
ADDAMS FAMILY (Bally) Motor bookcase 14-7969 1 $79.00 $79.00
ADDAMS FAMILY (Bally) Bookcase bracket 01-10398 1 $49.00 $49.00
Post stud 8-32 x 2-1/16 inch 9/32 top 02-4424-2 4 $2.89 $11.56
Post - star double clear 1-1/16 inch tall 03-8247-13 1 $0.80 $0.80
Screw 6-32 x 1-3/16 inch spiral fin shank 237-5957-00 15 $0.99 $0.89 $13.35
Hex spacer 1/4" f-f 8-32 x 2.83" 02-4436-5 1 $2.80 $2.80
Post stud #8 x 2-1/16 inch wood screw 02-4426-2 8 $2.55 $20.40
Bumper post 8-32 stud 6-32 top stud 02-4843 1 $4.95 $0.00 $0.00
Mini post 8-32 x 1/2 inch machine 02-4177 1 $2.75 $2.75
Bumper post 8-32 bottom stud 02-4057 6 $5.95 $35.70
Bumper post 8-32 bottom 6-32 top studs 02-4056 1 $2.95 $2.95
Bumper post 8-32 stud dual ring 02-4423 3 $3.95 $11.85
Post stud 8-32 x 2-1/16 inches 6-32 top 02-4424-1 10 $2.75 $27.50
Post stud 8-32 x 2-3/8 inches 5/16 drive 02-4425-1 1 $2.79 $2.79
Post spacer #8 x 1-3/16" 02-4435 2 $1.95 $3.90
Post spacer #8 x 1 inch 02-4434 2 $3.99 $7.98
Hex spacer 1/4 inch f-f 8-32 x 1-7/16 inch 02-4436-15 2 $1.95 $1.69 $3.38
Hex spacer 1/4" f-f 8-32 x 1-1/2" 02-4436-7 1 $2.90 $2.90
Post - star blue transparent 1-1/16 inch 03-8319-10 2 $0.79 $1.58
Post - star double clear 1-1/16 inch tall 03-8247-13 12 $0.80 $9.60
Bumper post 10-32 bottom stud 02-4036-2 3 $5.95 $17.85
Mini-post 8-32 thread 02-4003 10 $2.35 $23.50
Post - spring 02-3409 1 $0.95 $0.95
T-Nut 8-32 9/32 inch barrel -1/2 inch base 4408-01118-02 30 $0.35 $0.15 $4.50
T-Nut 8-32 1/4" barrel - 19/32" base 4408-01118-00 30 $0.29 $0.25 $7.50
T-Nut 6-32 thread 1/4 inch barrel 1/2 inch 3 prong 4406-01118-00 10 $0.29 $0.20 $2.00
#927 6 months ago
Thanks for the list!
Outside of all the hours put in on this project....under $6k for brand new one is good deal.
Do you have much left to purchase?
#928 6 months ago
Quoted from cpr9999:
I've been wondering about that myself.
I think all the major stuff is close to done.
The Pop bumpers are in
Bottoms are on
Targets are in.
Mostly complete book case and Thing are going in.
Subway Chute is on.
Scoops are On.
Lamp Boards should be arriving today sometime and will be on.
Reese Rails are on.
Some ramps are on.
Ball Trough is on.
95% of posts are on.
I have the plastics but can't install them yet.
I have the main ramp but can't install it yet.
I have the guide rails but can't bend/install them yet.
When the cabinet gets here, the transformer can go in
The Plunger can go in.
I have the back glass.
I will have a THING speaker board
I will eventually have the metal back board and non metal light back board.
I know I need the metal ramp.
I still need some metal ramps on the side.
I need the PCB boards in the back board.
I need some PCB boards on the bottom.
but it feels like there isn't that much left to buy in terms of MAJOR/big parts.
#929 6 months ago
thanks jeff
#930 6 months ago
You are going to have over 10 into it would be my guess...DMD, pinsound, and boards alone, and then there is the wire and what tooling choose for seating IDCs...The 10.00 stick works, but is really slow and less than a deliberate action of the gun...*Fun story, they make a cheap plastic die, and the commercial steel versions the difference between the two are around 2800.00 apiece (since there are 2 dies) in theory you could have 5k just in the guns, before even buying your first connector...I have tried all 3, and the stick sucked, and was unreliable connections, the plastic die broke on a cold morning, and the steel ones are so spendy I had to eat popcorn for 3 months.
#931 6 months ago
a quick test fit of THING to see how well he was setup.
I can clearly tell it won't clear the hole at this point.
95934205_10157999767785211_1090290904222138368_n (resized).jpg96351710_10157999767890211_1163059049059581952_n (resized).jpg
I don't know what size connector the little round part needs to fit in so it stays attached to the rod.
#932 6 months ago
Your Thing hand appears to be facing the wrong direction...
#933 6 months ago
Quoted from Steve_in_Escalon:
you know I realized that as soon as I put it on.I wonder if it'll clear the hole any better if I flip the thing around.
But I had to replace the screws anyway that attach it to the motor so I just left it that way.
I was looking at an angle from a different direction and must have put it on the wrong way...
#934 6 months ago
thanks jeff
Hey 565
Respectfully, you really should be thanking Steve (Dankme). It took him literally weeks to do the lampboard drawings and iteration to dial them in vs minutes to order.
Wally
#935 6 months ago
SKU: 20-9247_coil
⋮ SAVE TO WISH LIST
Quantity
3
$29.95
$89.85
1
SKU: 23-6629
Quantity
1
$1.50
$1.50
$0.80
⋮ SAVE TO WISH LIST
Quantity
1
$39.95
$40.75
$0.80
⋮ SAVE TO WISH LIST
Quantity
1
$39.95
$40.75
$0.80
⋮ SAVE TO WISH LIST
Quantity
1
$39.95
$40.75
$0.80
Quantity
1
You a Beast! You can Do it!
#936 6 months ago
Quoted from wallybgood:
Hey 565
Wally
Absolutely Wally! I was only a facilitator, not the creator. Steve is an awesome guy!
#937 6 months ago
Hey 565
Wally
yep, my bad. that too. I just had more contact with jeff so that sprang first to mind
#938 6 months ago
Magnet Coils and Flipper assemblies shipped.
That just leaves the topper and 3" guide rail left in limbo.
#939 6 months ago
Hey shredder565 ...You will have better luck asking these kinds of questions and anything related to making a scratch TAF build in the remake fb group. There are a bunch of people in there who have already completely made an Addams from parts and/or are currently making one. Not everyone who is making/made one and can answer these questions watches your thread here.
Not sure if you are asking how to wire the boards themselves or the wires going to the boards, but I attached an image of what the TAF lamp boards that I made should look like when finished. This was my first attempt at making ANY PCBs and I wasn't intending to sell them or anything so they are not 100% exact to the originals (which I didn't have). Mainly the screen printing is different and there are probably slight sizing differences as well. Anyway, in the TAF parts list on ipdb.org you can see the diodes, lamp sockets, and Molex connectors needed to finish them. If you have another game with lamp PCBs, you can use that as a reference as well to see how they are made. When you wire it up, you will need to use the lamp matrix to see what wires go where. Hope that helps.
#940 6 months ago
IT def helps
I now know how many points need to be soldered, and what they are supposed to look like finished.
it'd be kidn of fun to power 'em on somehow just to make it look like it's on when done if possible ;o).
Flippers get here tomorrow. as does the rest of the order.
that just leaves the topper and guide rail.
#941 6 months ago
OK, progress. I found the position of one light board, even though I know that is not how they go on. I think I am missing stands.
Thing is properly re asserted. even though still missing proper screws for some things, at least they won't fall off for now.
Next, trying to install the flippers properly.
At least the magnets where easy
96430353_10158005685380211_8265001186273263616_n (resized).jpg97278560_10158005685285211_7641372961391247360_n (resized).jpg97725545_10158005685315211_8797307445685780480_n (resized).jpg
#942 6 months ago
Yes, you definitely need spacers for the boards.
#943 6 months ago
when I was looking at images, it seems they are also flipped the other way and metal against even wood obviously not good.
any ideas on where to get the spacers?
#944 6 months ago
Do you have the twist on sockets for the boards?
Any 1/2" #6 spacer will work.
Ace hardware usually has a good selection of black nylon spacers.
Marco has the clip on ones specific for this.
Someone here can measure the exact length or check the BOM list.
#945 6 months ago
Marco type in plastic spacer.
#946 6 months ago
it's starting to slowly look like something.
#947 6 months ago
Parts list is your friend. You need to populate those PCBs with the .156 headers and diodes before you screw them down (with the spacers installed).
03-8022-1 #6 spacer .541"
#948 6 months ago
Quoted from Ricochet:
yep, I knew I had to populate them first. But I wanted to make sure I had the proper spots for them first while I waited for parts to be ordered
does this spacer look right?
https://www.marcospecialties.com/pinball-parts/03-8022-1
#949 6 months ago
yes... but you could find an alternative as long as the height is correct and it will fit a #6 screw. The nice thing about the original part is that it clips into the PCB and stays there so you can pre-build it or remove it from the play field without the spacers falling off. The holes in your PCBs are a bit larger than the #6 screw to accommodate for the clip on the standoff.
#950 6 months ago
Yeah the clip in spacers are nice, I’d Order and wait for those to come. U can order headers and diodes and get those coming while your at it.
The metal around each light hole faces down and makes contact with the plastic light socket holder contacts when you turn it a quarter turn to ‘screw’ it onto the pcb.
$ 109.99
Various Novelties
Pinball Photos LLC
$ 25.99
Lee's Parts
$ 159.99
$ 39.00
Concealed Art
$ 48.00
Creo Pinball
$ 54.00
Loop Combo Pinball
$ 39.99
Lee's Parts
$ 29.00
Filament Printing
$ 29.00
Pinball Photos LLC
$ 279.95
Pin Stadium Pinball Mods
$ 54.99
Comet Pinball
$ 99.00
Loop Combo Pinball
Denver, CO
$ 8.50
Allentown, PA
Creo Pinball
Knoxville, TN
$ 65.00
€ 60.00
Creo Pinball
$ 62.00
$ 38.99
Lee's Parts
$ 75.00
pinballmod
$ 14.95
