(Topic ID: 257696)
Addams Family - Scratch Build?
By Shredder565
Topic poll
“This project is”
  • Ambitious 118 votes
    41%
  • insane 140 votes
    49%
  • will be undone by a official remake in a few months..:) 28 votes
    10%
(286 votes)
There are 5,844 posts in this topic. You are on page 115 of 117.
#5701 23 days ago
Quoted from Shredder565:
missing piece back in, but needs super glue.
Use a small drop of epoxy.
Super glue is too brittle and will crack out.
#5702 23 days ago
the goal is to get this thing in playable mode in two months. how many parts are missing?
Besides the obvious of the Bear Kick and the Flip switch near 'ramp' near it.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
This is way wrong !
This small flatrail doesnt go there:
Remove that rail and add a double metal post like this.
https://www.marcospecialties.com/pinball-parts/02-4423 :
dont worry about the extra screw hole in the playfield.
either put the screw back in the hole to cover or just remove it.
you wont see it under the ramp.
#5703 23 days ago
I'm trying to think positive, considering it's already taken 4 years to get this far
So your doing better than CGC
#5704 23 days ago
I'm not the slowest? that's a first
removed the rail.
and one of the nuts doesn't want to unbolt :/. Had to cut the plastic but now I need to find a way to get the thing totally out so I can put the rubbers on.
448671806_10161140618770211_4345558901745638252_n (resized).jpg448671806_10161140618770211_4345558901745638252_n (resized).jpg448703986_10161140618805211_1226979670272641497_n (resized).jpg448703986_10161140618805211_1226979670272641497_n (resized).jpg
#5705 23 days ago
The t nut probably not installed correctly see if the spins with the Tnut under playfield..
Don't cut stuff off at this point!
#5706 22 days ago
removed the rail.
and one of the nuts doesn't want to unbolt :/. Had to cut the plastic but now I need to find a way to get the thing totally out so I can put the rubbers on.[quoted image][quoted image]
You houldnt have to remove anything really.
Stretch the rubber so that its thin and it should clear most obstacles.
If t-nuts are spinning, anchor them with a screw under the playfield in one of the t-nut flange notches.
#5707 22 days ago
OK, one of the bits was stripped, so got it off without damaging the T Nut. but, will have to replace the plastic piece. also, is there a THIRD post that should be here? which one am I missing?
448769085_10161142101805211_3429117620925975956_n (resized).jpg448769085_10161142101805211_3429117620925975956_n (resized).jpg
#5708 22 days ago
alright. dummy me figured it out. I put the rubber on the one post. moved the rail to the proper spot. now, what one goes to the left of the double star post? does that look right?
and the double star post on the right side of the bumper.
448866076_10161142309825211_814342085649385862_n (resized).jpg448866076_10161142309825211_814342085649385862_n (resized).jpg
#5709 22 days ago
and the double star post on the right side of the bumper.[quoted image]
There are myriad images of teardown photos on Pinside that you can comb through and check placement for everything. You should be able to do this stuff without all the hand holding.
#5710 22 days ago
Since my game is still on the bench, some hand holding, lol...
Make the whole area look like this:
Use a popsicle stick or a stiff plastic scraper to FORCE the tapered yellow bumper in.
Dont forget the tiny #2 round bead screws in the flatrail to the siderail. Drill a hole for the screws or the head will pop off (ask me how I know this...).
ALSO, dont forget the similar screw in the backboard to the long outer loop.
Without it the loop will RISE UP and down unpredictably.
Theres also one in the shooter lane ramp
Its damn near impossible to install the tiny screws unless the game is totally take apart.
#5711 22 days ago
Quoted from A_Bord:
There are many things I "also" SHOULD be able to do......but its getting harder every day....
#5712 22 days ago
Quoted from pinballinreno:
bingo. when ones mind is being pulled in MANY different directions, it helps to get it right the first time. for instance, I was wrong where one of those yellow rubbers went and right where two others where..
in other news, I went through the 100 or so photos posted in the past day, trying to figure out which where mine and which where not. and I THINK this looks right now.
#5713 22 days ago
It's damn near impossible to get this one ON. I barely squeezed the wrong black sleeve on there. not sure how i'm going to squeeze the yellowish one. it's too thick.
#5714 22 days ago
Use a little windex and they slide right in.
The tapered yellow one takes a bit of pressing and pushing with a popsicle stick near the flatrail, a little windex helps a lot.
#5715 22 days ago
This post next to the clear pop uses a screw NOT a threaded toppped post (please see my pictures):
#5716 22 days ago
This post next to the clear pop uses a screw NOT a threaded toppped post (please see my pictures)[quoted image]:
yeah, that was one of the things I noticed and changed. it should look right now.
I'm going to have to leave that yellow bumper for monday. heading out in a bit. I'll try the windex trick.
I am also going to replace some of these metal pieces with proper bents.
448671420_10161142528960211_5734661793749832356_n (resized).jpg448671420_10161142528960211_5734661793749832356_n (resized).jpg448762848_10161142529100211_4080921529224598512_n (resized).jpg448762848_10161142529100211_4080921529224598512_n (resized).jpg448920638_10161142528990211_5617413311301080735_n (resized).jpg448920638_10161142528990211_5617413311301080735_n (resized).jpg
#5717 22 days ago
Put your "Big Girl Panties" on and firmly press that yellow sucker down with a stick or flat blade screwdriver etc...
Some people use a socket from a ratchet kit, whatever works.
Yes it a tight fit. Obviously it will fit with patience and perseverance!
The electric chair is still backwards on its bracket...
Pull the whole chair assembly off, pull out the bracket, flip the chair bracket around and re-install it.
#5718 22 days ago
I was afraid of wrecking the thing. well... it's not pretty, but it's on!
Also the fixed screw post.
and yeah, the electric chair is going to follow your previous posts a few page back....it's on the list..
448716865_10161142570835211_8231252235079971579_n (resized).jpg448716865_10161142570835211_8231252235079971579_n (resized).jpg448889241_10161142570800211_5457134740780437284_n (resized).jpg448889241_10161142570800211_5457134740780437284_n (resized).jpg
#5719 22 days ago
had to move this part up a bit to get the rubber on. it was too close to the flipper for it to work right.
is this metal part supposed to go through the hole?
noticed this while I'm moving the other part. I didn't think so.
448726899_10161142567315211_2801726780777804061_n (resized).jpg448726899_10161142567315211_2801726780777804061_n (resized).jpg448763891_10161142566970211_8668720072044847961_n (resized).jpg448763891_10161142566970211_8668720072044847961_n (resized).jpg
#5720 22 days ago
Yes the ramp should be assembled. I welded mine.
#5721 22 days ago
Yes, thru the hole. Its just clipped on via the bent tongue tab.
Sadly after all that work, you have to remove the tapered yellow rubber.
(ARE YOU F#CKING KIDDING ME ! ! ! ! , No, Im not.)
You are MISSING the flatrail that goes behind it (PLEASE look at the picture I posted).
One step forward, 5 steps back.... at least in my world, lol.
#5722 22 days ago
it was there. I plan on replacing those two. and it would be easier sliding it on without it there than with it. it was tight enough where it was as it was.
#5723 22 days ago
It will be tough to get the flatrail on with that tapered rubber in place.
#5724 21 days ago
FWIW, I've owned a couple TAF, shopped several, worked on several, I never remember seeing a yellow cone on that post under the ramp. I've run TAF on location for about 8 years, and I never had a problem with a ball getting stuck in that location with a regular black post sleeve on there. Put a black post sleeve on it and be done with it.
#5725 21 days ago
Quoted from stangbat:
I somewhat agree on this.
Its a curiosity as to why these tapered rubbers pop up on some games.
Its possible that they keep the ball down low on the playfield to help with air-balls.
I imagine that a regular post sleeve would function just the same other than air-ball protection.
But, they do look cool.
#5726 21 days ago
like the photon torpedoes....and tractor beam...the new rails get here tuesday.
#5727 20 days ago
otpo boards ordered for the lower flipper side.
so, is it agreed that a black one is ok there rather than the yellow one? I rather like the yellow. it looks different. it's just a pain in the butt to put on. I guess I could slice off a tad bit of the back so it goes on easier.
#5728 20 days ago
I put the yellow one. Trimming it isnt a bad idea.
It was tight, but not impossible.
I just pressed it on firmly, front to back a bit. Then pryed it with a plastic razor blade a bit, to help it down the back edge.
Always a little windex helps post sleeves slide on. I just spritz it inside the sleeve, then wipe off the outside snd slide them on.
#5729 19 days ago
And a little Hawk Tuah goes a long way. Gotta spit on that thang!
https://www.facebook.com/share/r/kwShExvjbkFoUsrd/?
#5730 19 days ago
Quoted from dmacy:
I must have missed a story. what's this video all about? seems everywhere now. there is one going around about a guy and a girl randomly meeting and going on a date later or something, but I don't think this is that one.
#5731 19 days ago
todays job. get the phone flashers upper ramp flasher and lower ramp flasher done.
#5732 19 days ago
It’s some girl saying she likes to spit on it and has gone viral. I’ll let your mind wander but was just associating lol.
#5733 19 days ago
it only took a second of wandering to think that's enough ;o)
three done, three to go.
448881813_10161149223415211_8718588175228208804_n (resized).jpg448881813_10161149223415211_8718588175228208804_n (resized).jpg449064370_10161149223440211_690976112713149676_n (resized).jpg449064370_10161149223440211_690976112713149676_n (resized).jpg
#5734 19 days ago
it's been a while. but I believe the t wo on the bottom are the opto wires and the red and black on the top are the flashers. will have to look.
449084271_10161149245640211_6148005890030766179_n (resized).jpg449084271_10161149245640211_6148005890030766179_n (resized).jpg
#5735 19 days ago
three done, three to go.[quoted image][quoted image]
Thanks for the lamp boards Davi !
#5736 19 days ago
Your riveting skills have drastically improved!
#5737 19 days ago
It's still about 60/40. but better
Some progress. Phone Flasher 1 works. I have to find out which blue/red wires to attach the other one too.
Train Black/Red flasher doesn't seem to want to work.
Hooked up flipper Black/Red Flasher, that one doesn't seem to work.
But, I noticed that one has two wires heading into it...so maybe I need to hook up the ramp ones for them all to work.
I have one blue wire running out pre done for the flipper flasher...gotta run a black wire out.
#5738 19 days ago
The Jobs for this week. Try and get the Bear Kick Ramp into something resembling finished nature.
Long way to go.
remaining upper body parts in the background.
449039106_10161150027210211_7299761236589629338_n (resized).jpg449039106_10161150027210211_7299761236589629338_n (resized).jpg
#5739 19 days ago
Other remaining jobs for this week.
Figure out which blue/red wires are for the phone flasher.
which ones are for the flipper flasher.
Hope the TRain flasher works when the ramp gets hooked up, and then figure out how these attach by looking at the photos posted.
lots of stuff to go back through.
If I can get this far by either this week, or the fourth, maybe a bit of break time.
after that, that should be all the MAJOR stuff done.
and by major, I mean, close to getting a first test game done major to see what still needs fine tuning. and I'm willing to bet there will be stuff
448830676_10161150027230211_4040980702627720766_n (resized).jpg448830676_10161150027230211_4040980702627720766_n (resized).jpg449040671_10161150027280211_7839430695653827212_n (resized).jpg449040671_10161150027280211_7839430695653827212_n (resized).jpg
#5740 17 days ago
Finally got my switch harness repaired and installed today.
Next, repair and install the lamp harness.
#5741 17 days ago
ok, some progress. Got both of these extra flashers working, left flipper and swamp. but not the Train Flipper or the one above this one yet. hoping those start working when I hook up the ramp.
The only thing I still can't find are the extra wires for the phone flasher #2. there are no extra dangling wires to attach it to. so, I probably have to get my non color guy in here and identify the proper wire color for this one.
449164783_10161153896655211_7512499888878764939_n (resized).jpg449164783_10161153896655211_7512499888878764939_n (resized).jpg
#5742 17 days ago
I’m curious what tool and rivets Shredder565 uses to rivet. Honestly, impressed by the results as well Well done!
#5743 17 days ago
Quoted from MiniPinHead:
that would be the pintonka rivet tool.
so easy, even I can do it
https://www.pintonka.mountainminded.net/
#5744 17 days ago
have to figure out how to attach and wire the opto's.
449087443_10161153937385211_5909235904563382042_n (resized).jpg449087443_10161153937385211_5909235904563382042_n (resized).jpg
#5745 17 days ago
need that extra missing piece posted a few pages back. also need to see how these properly line up.
449117407_10161154007440211_1519422853324819970_n (resized).jpg449117407_10161154007440211_1519422853324819970_n (resized).jpg
have to use a shorter screw as well.
#5746 17 days ago
have to figure out how to attach and wire the opto's. [quoted image]
I believe you're looking at these two sections of the Parts Index:
1128 .2 A-15197 opto ball gde assy-in 1
1129 ..3 A-15196 opto ball guide sub-assy-in 1
1130 ..3 H-15235 opto detect cable 1
1131 ...4 H-15235-C opto detect cable-cut 1
1132 ....5 CW-30022-84 wire 22awg gry/yel 7.25
1133 ....5 CW-30022-35 wire 22awg org/grn 7.25
1134 ...4 5791-10772-00 2P11625 03-06-2023 1
1135 ...4 5820-09078-00 pm1560 02-06-2101 2
1136 ...4 03-7520-2 tie wrap-nylon 3 7/8 2
1137 ..3 A-16909 opto p/t assy 1
1138 ...4 03-8506 base-opto mtg-black 1
1139 ...4 4104-01001-06 sms #4X3/8 p-ph-a 1
1140 ...4 A-14232 photo trans assy 1
1141 ....5 5768-13154-04 pcb-phot trans 0
1142 ....5 5163-12732-00 trans npn photo 0
1143 .....6 5163-14114-00 trans-photo infra red T1&3/4 0
1144 ..3 4106-01013-06 sms #6 x 3/8 p-ph t-25 2
1145 .2 A-15199 opto ball gde assy-out 1
1146 ..3 A-15198 opto ball guide sub-assy-out 1
1147 ..3 H-15234 opto transmit cable 1
1148 ...4 H-15234-C opto transmit cable-cut 1
1149 ....5 CW-30022-0 wire 22awg black 7.25
1150 ....5 CW-30022-86 wire 22awg gry/blu 7.25
1151 ...4 5791-10772-00 2P11625 03-06-2023 1
1152 ...4 5820-09078-00 pm1560 02-06-2101 2
1153 ...4 03-7520-2 tie wrap-nylon 3 7/8 2
1154 ..3 A-16908 opto led assy 1
1155 ...4 03-8506-1 base-opto mtg-white 1
1156 ...4 4104-01001-06 sms #4X3/8 p-ph-a 1
1157 ...4 A-14231 led assy 1
1158 ....5 5671-12731-00 led diode infra red 0
1159 ....5 5768-13155-02 pcb-single IR LED (green mask) 0
1160 ..3 4106-01013-06 sms #6 x 3/8 p-ph t-25 2
So it looks like you just need the bases, screws, and mounting hardware for the Infared LED Opto Assembly - Transmitter and Infared LED Opto Assembly - Receiver for the opto ball guide in and out assemblies
Here are the cheapest bases:
Black (Receiver): https://www.pinballlife.com/PBL-300-0024-00-58
White (Emitter): https://www.pinballlife.com/PBL-300-0024-00-40
I know you (ha), so here is Marco:
Black (Receiver): https://www.marcospecialties.com/pinball-parts/03-8506
White (Emitter): https://www.marcospecialties.com/pinball-parts/03-8506-1
One sheet metal screw connects each opto PCB to its associated base: #4 x 3/8" Phillips Pan Head Sheet Metal Screw
Examples:
https://www.homedepot.com/p/Everbilt-4-x-3-8-in-Phillips-Pan-Head-Zinc-Plated-Sheet-Metal-Screw-16-Pack-812661/204275188
Or
https://www.marcospecialties.com/pinball-parts/4104-01001-06
And two machine screws with SEMS connects each opto base to the ball guide: #8-32 x 3/4" Phillips Pan Head Machine Screw SEMS
Example: https://www.marcospecialties.com/pinball-parts/4008-01003-12
If you ever need more opto sets that are complete, you can save ~$1 per set by getting them preassembled here: https://www.pinballlife.com/williamsbally-infared-led-opto-assembly-set.html
It looks like you just need the one opto set of bases and hardware, so here's a SUMMARY of what you need:
x1: https://www.marcospecialties.com/pinball-parts/03-8506
x1: https://www.marcospecialties.com/pinball-parts/03-8506-1
x2: https://www.marcospecialties.com/pinball-parts/4104-01001-06
x4: https://www.marcospecialties.com/pinball-parts/4008-01003-12
Thanks again for the rivet press recommendation. It does seem pretty empowering to be able to use one. I'm sold on it, thank you!
And you being able to use one is a selling point, but only because you find it practical and your results look great
#5747 17 days ago
So added in cart.
and before I hit order, got the proper color wires for the bear kick lights. that should be the last of them. only about 4 or so switches left.
and I need to find this part before I hit order on the marco bit.
#5748 17 days ago
So added in cart.
and I need to find this part before I hit order on the marco bit.[quoted image]
Im still not clear on what part is missing?
I guess post a better picture or the area thats missing it?
And circle it maybe?
Im a bit confused.
#5749 17 days ago
I went looking through the pictures, and Ican't find it. it's tough to tell yours apart from mine. it was a part that you said was on one of the guard rails that need to be on there or else the rail will flip up and down.
#5750 17 days ago
The optos, if you bought the ones I gave you the link to, have plastic mounting brackets that come with them.
Then they are attached to the flatrail with sheet metal screws, try not to strip them out.
$ 159.00
Plantsville, CT
$ 145.00
Twisted Tokens
$ 28.99
Lee's Parts
$ 41.99
Lee's Parts
Twisted Tokens
$ 29.00
Filament Printing
$ 24.00
Various Novelties
Pinball Photos LLC
Uberlaser
$ 55.00
Twisted Tokens
$ 27.99
Rubber/Silicone
Comet Pinball
$ 180.00
$ 449.00
$ 58.00
$ 320.00
Avid Creations Wireforms
Lenticular Designs
$ 119.00
pinballmod
9,000 (OBO)
Los Angeles, CA
$ 119.00
Loop Combo Pinball
Trade
Machine - For Trade
Mesa, AZ
$ 41.99
Lee's Parts
$ 109.99
$ 119.00
15,000 (Firm)
Carpentersville, IL
$ 29.95
$ 26.99
Lee's Parts
$ 449.00
