(Topic ID: 302324)
Addams Family Multiball Glitch
By Gorbiie
1 year ago
  • 15 posts
  • 5 Pinsiders participating
  • Latest reply 1 year ago by Pin-Pilot
#1 1 year ago
I noticed something strange with my TAF after locking the first two balls for Multi-ball. Once the chair and vault red lights turn on my turn doesn't end if I drain the third ball. If I drain the third ball the game will eject the ball back into the shooter lane and I am able to continue shooting on that same turn. Once I start Multi-ball, it does register the drains. It seems like a glitch because I can continue shooting ramps with no fear or drains with the third ball.
I noticed that the ball eject is continuously running during this "red light" time. The game is working perfectly beside this issue. Does anyone have any idea what's causing this? I'm assuming this isn't normal.
#2 1 year ago
You found the rare "Ball Save" feature that TAF does not have. All kidding aside, that is an interesting issue you have going there of which I am no help.
I am trying to think through what might possibly cause this.
The continuous ball eject cycling during "red lite" time is not right. Should not run continuously at all.
This leads me to believe there may be an issue with your ball trough switches. I would look those over real well to make sure they are not jammed or stuck.
#3 1 year ago
Could you post the ROM version your game is running?
The version will be shown at boot.
Chris Hibler - CARGPB #31
http://ChrisHiblerPinball.com/Contact ... for board repairs
#4 1 year ago
You have a stuck switch in the ball trough
Check all the arms and switches
It’s prolly the one closest to the shooter Lane
Make sure it functions properly
You’ll get a switch alert soon
Seen this before
#5 1 year ago
Quoted from TheCnyPinGuy:
TheCnyPinGuy I think you are right. Good call. That would explain how the outhole switch can work but the game still doesn't know where all three balls are.
But why would the game serve another ball? It seems like it should go into ball search.
#6 1 year ago
Quoted from ChrisHibler:
If 2 balls are locked
Game will serve the ball
But there is a closed switch in the furthest to the shooter lane - its stuck closed so the game “thinks” it never served the ball
I bet it’s the armature on that switch and the wire slide just enough where it is stiff and has no ‘spring’ now stuck closed
A78E7810-47C9-4882-9062-AEAFA6CB23FB (resized).jpegA78E7810-47C9-4882-9062-AEAFA6CB23FB (resized).jpeg
#7 1 year ago
Thanks for the replies. You guys nailed it.
I inspected all the switches and none were stuck or malfunctioning. I noticed the alignment of wire (?) connected to the switch closest to the shooting lane was aligned in a way that it didn't spring back up when the wire from the ball trough fell down on it. This occurred without a ball in the trough, which makes sense why the issue was present during third ball multi-ball.
Solution: I repositioned the switch wire so it had more tension and didn't fall as easy. The shooter eject no longer fires continuously during 'red light' mode and the game is able to recognize drains during "red light" mode (fortunately or unfortunately).
New issue: I'm now seeing the continuous shooter eject firing after a ball is ejected into the shooter lane. Fires a few times and then stops. Do you think it's best to try to continue repositioning the switch wire, or replace the switch/wire?
#8 1 year ago
TheCnyPinGuy Doh! I missed that when I read it the first time. Again...good call.
#9 1 year ago
http://www.PinWiki.com - The Place to go for Pinall Repair Info
We all helped
Game is fixed that’s all that matters
#10 1 year ago
Quoted from Gorbiie:
I would try repositioning the switch wire again. If it keeps on happening, then I would replace the switch.
#11 1 year ago
The fact the ball eject was running continuously was the big giveaway. The game thought there was still a ball there that needed to be ejected but would not stop game play. Why I mentioned checking the trough switches. Glad we were able to help you out.
#12 1 year ago
Looking closer at the pic you posted of your trough switch, the switch arm should be a flat arm and not a wire arm. Your switch arm is the wrong one. it should be a flat metal arm not a wire arm.
Here is the switch you need: https://www.marcospecialties.com/pinball-parts/5647-12693-08
Here is a pic out of the Owner Manual for TAF
Screen Shot 2021-10-19 at 9.42.26 PM (resized).pngScreen Shot 2021-10-19 at 9.42.26 PM (resized).png
#13 1 year ago
Here ya go, I am back home and got a pic of the Trough of my TAF.
#14 1 year ago
Pin-Pilot Good catch and thanks for the pic! I'm going to order the right switch.
#15 1 year ago
The fun of getting a newly acquired pin up to par. I am sure you will find more hidden gems to fix. Part of the fun of getting a new pin in the house.
I just noticed you are in Scottsdale. I have a switch if you do not want to order one and have to pay for shipping. Let me know.
$ 1.29
Daddio's 3D Printed Mods
Toys/Add-ons
$ 16.00
$ 320.00
Avid Creations Wireforms
Other
$ 8.50
Led
Other
$ 399.95
Pin Stadium Pinball Mods
Led
11,500 (Firm)
Sunrise, FL
$ 55.00
Twisted Tokens
Toys/Add-ons
$ 79.00
Lighting - Under Cabinet
Arcade Upkeep
Under cabinet
$ 24.00
Various Novelties
Pinball Photos LLC
Various novelties
$ 399.95
Led
Sparky Pinball
Toys/Add-ons
€ 47.00
PPmods
Toys/Add-ons
Other
$ 54.99
Shooter rods
Precision Pinball prod.
Flipper parts
Twisted Tokens
Toys/Add-ons
$ 29.00
Filament Printing
Other
$ 24.25
The MOD Couple
Toys/Add-ons
Loop Combo Pinball
Other
$ 54.99
Shooter rods
$ 58.00
Toys/Add-ons
10,950 (OBO)
Maricopa, AZ
$ 9.95
Little River, SC
Armor and blades
$ 159.99
Other
This page was printed from https://pinside.com/pinball/forum/topic/addams-family-multiball-glitch and we tried optimising it for printing. Some page elements may have been deliberately hidden.
