When I hit the left flipper button at times I get the graveyard bubble sound or may be the swamp and get 25k points. This can’t be right. Went to the sound diagnostic and can’t even find the sound. Anyone else had this issuer?
Tests - Switch Edge - bang on playfield. The switch that registers on the DMD is too sensitive and needs adjusting.
Yea check switches in test . Also close the door to get power and hit the flipper to see what it’s triggering . Also you can hit those switches in game play to see which sound you are hearing and also watch the scoring . Helps narrow down things . Like LTG said as well, I find a lot by banging on the playfield . Good luck .
Found the opto 57 when hitting the bumper. Cannot find the opto switch though. This make sense guys? Does the opto make it sound like the ball has gone in the swamp?
Quoted from MMarks3:Cannot find the opto switch though.
Check the switch location map in the manual.
Right up from the mini flipper on the left.
This page was printed from https://pinside.com/pinball/forum/topic/addams-family-issue-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
