Hi all,
I'm desperately looking for advice on how to fix some flipper problems on my TAF. All four flippers have had very intermittent, weird things happening that make the game unplayable.
At times the bottom right flipper does not respond at all when pressing the button but the upper right flipper does work, sometimes both work perfectly. Other times the upper left flipper does a double flip motion while the bottom left is fine. Ive also found that sometimes when I hold the left flipper button in all the way, both flippers activate and stay in the up position then the upper flipper goes down while I still have the button pressed, it does not happen every time however.
This is what I have done so far to fix the situation:
Replaced all four coils
Installed a new Rottendog Fliptronics II board
Installed new flipper button switches
Ive made every attempt to adjust all of the switches on the all four of the coils and the flipper button switches, the spacing looks correct as far as my eye can tell.
Ive re-seated every connector related to the flippers in the back box many times.
All of the solder points on the flipper button switches and coils look solid
All fuses are good
Any advice on what I should try next?
Thanks so much!
