(Topic ID: 259450)
Addams family flipper issue
By Karpy1717
11 days ago
  • 46 posts
  • 4 Pinsiders participating
  • Latest reply 5 days ago by Karpy1717
There have been 11 images uploaded to this topic. (View topic image gallery).
#1 11 days ago
Hi everyone! I’ve had problems with my flipper eos switch not activating. As advised by a pinball friend they said to lightly sand the contacts( I don’t think this was right) and now my upper right flipper will not activate. I have no idea what to do but I can post pictures if needed. Thanks for your help in advance
#2 11 days ago
Your EOS was gold plated, you ruined that. Not the end of the world, replace, or sand if it ever needs it.
You should have been looking for a broken wire at the other EOS switches first, from them, to the fliptronics board, check the other EOS's first.
Next up, check the fliptronics board for a blown fuse. And Tests - Switch Edge - see if flipper button leaf blade switches both register on the DMD. Two on each flipper button. Push in slowly, first lowers register then uppers, when you push the flipper button in. Be sure both flipper button switches work.
#3 11 days ago
Wow I’m silly... eos was broken wire.... I soldered that up. I’ll do the switch test and get right back to you
#4 11 days ago
So now to the flipper... they both activate in terms on the switch test. No errors popping up at all. The only thing now is the following:
The main right flipper activates but has a hissy fit and returns to off position after moving crazily. The upper does not Activate at all
#5 11 days ago
Quoted from Karpy1717:
If both switches work, you now have an issue on the fliptronics board.
No idea what, sorry.
#6 11 days ago
Quoted from LTG:
I didn’t think that was possible
#7 11 days ago
Well I did a little digging.... when the upper flipper switch touches it doesn’t register so I think I’m just going to replace that. I was wrong when I read it on the screen. Basically the two pucks touch but don’t activate. Is the best thing to do replace the flipper system?
#8 11 days ago
Figure out what is wrong first. Remember how this started. Look at the dedicated switch column in your switch matrix. Don't be ignoring a broken wire again.
Quoted from JayDee:
Very possible. I'm not standing there when mistakes were made. So no accurate way of knowing what all happened.
#9 11 days ago
Alright so this is what happens... r flipper button and r flipper eos activate. For the upper r flipper button activated but not eos. The little pucks are making full contact.
Essentially bottom one works top doesn’t. Before sanding they both worked
#10 11 days ago
The right flipper doesn’t stay out either
#11 11 days ago
Grab a meter and check wires from EOS to fliptronics board.
Do you mean you in game play you push the flipper button and it goes up and drops ? If so go over solder joints at the coil.
#12 10 days ago
Alright so basically the flipper pushes out and returns back. Power is going there but not staying. I wish I could send you a video but I don’t think that is possible. I just re soldered all the wires connecting to the coils and flippers but ultimately it’s exactly the same... here are pictures in case you could spot something
image (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpgimage (resized).jpg
#13 10 days ago
Basically when the two pucks touch it registers in switch test but no power is going to second flipper
#14 10 days ago
The other thing is that the only thing I did was sand the connections of the flipper pucks. So I have to assume that those are just not working and I should replace it
#15 10 days ago
No, I'm sure they work. You need to check continuity of them from the EOS lugs to the fliptronics board.
If both leaf blade switches register in Tests - Switch Edge, I'd try swapping flipper coil with another. If they don't register in Tests - Switch Edge - check continuity from the flipper button switches to the fliptronics board.
#16 10 days ago
Alright I know this doesn’t sound good but what is a fliptronics board . I’m rather new to this all. I’m just annoyed since before I sanded it worked and now it won’t... do I need to go buy a meter to test the power flow to the board?
#17 10 days ago
When you are facing the game - the board in the top left corner of your backbox, above the CPU.
You can download the manual from here, if you don't have one. It will help you identify boards and what connectors on them to check :
https://www.ipdb.org/files/20/Bally_1992_The_Addams_Family_Manual.pdf
You need a meter, a cheap one will do. And check continuity first, not power.
Youtube is littered with how to videos. Use a meter, check continuity, etc. etc.
If you did his with the game turned off, just a coincidence, not something you did.
#18 10 days ago
Yep I did it while turned off... I’ll go get a meter and get back to you. Thanks for all the help
#19 10 days ago
Aren't those EOS switches normally closed?
#20 10 days ago
Not on mine
#21 10 days ago
Also is there anything in particular I need to check on the board?
#22 10 days ago
Quoted from Tbachli:
No.
The fliptronics board - yes, the fuses. Pull and check with a meter.
#23 8 days ago
Alright!!! I got a meter I’ll attach a photo so you can tell me if it’s the right setting. Which fuses do I need to look at???
#24 8 days ago
No, set it on ohms or diode. Watch some Youtube how to videos.
The ones on the fliptronics board.
#25 8 days ago
Not sure what this fuse does but it’s completely blown so I removed it..:
#26 8 days ago
Alright I tested every fuse in the whole game and besides that broken one they all were .09 on this setting
#27 8 days ago
Is the blown one a flipper fuse?
#28 8 days ago
Check your manual. Replace it.
#29 8 days ago
F902 is for upper right flipper.
#30 8 days ago
Well that’s perfect!!! What about the bottom flipper going out and returning really quick??? Is that a fuse thing because I soldered it up and nothing was fixed
#31 8 days ago
I’ll fix the top one I got to go to a store but they are closed because of snow
#32 7 days ago
Got a fuse, flipper works. However the main bottom right flipper still sticks out partially and returns. How should I trouble shoot this
#33 7 days ago
Move it by hand - determine mechanical or electrical - could need a new plunger, coil sleeve, coil stop.
#34 6 days ago
I’ll go take a look right now!!!
#35 6 days ago
Alright so basically what happens is it goes out all the way and instantly returns. Looking at the coil it just won’t hold out??? So maybe it’s power going to it I’m not sure. When moved by hand it feels normal and Nothing appears wrong. I’d say electrical
#36 6 days ago
Try a different coil.
#37 6 days ago
Alright I will do that. Just as an add on it seems to double fire at the end and then return? Probably a coil like you said.
#38 5 days ago
Or wiring at the coil lugs.
#39 5 days ago
Would taking a meter to it tell me anything?
#40 5 days ago
No.
#41 5 days ago
Alright I’m just going to buy a new coil and hope it’s that!!! No way I’m able to rewire so I’d have to get someone to do that for me
#42 5 days ago
Be sure they know what they are doing. Didoes on coil facing the same direction, wires in the same spots.
#43 5 days ago
Alright so I just called up my pinball store and they said they don’t think coil is dead since it does fire. They said it could be something to do with fliptronics board. Any idea what I need to look for?
#44 5 days ago
I don't think it's dead. I do believe you have a bad solder joint at the coil lugs. Or one of the thin wires from the coil to the coil lug is cracked or broken. Or one of the two windings inside the coil is bad.
I suggested a new coil, because that would eliminate three potential problems.
You could use some hands on help with this so you quit chasing back and forth and get the game fixed so you can enjoy it.
#45 5 days ago
Sounds good!
#46 5 days ago
Got a new coil and it works!!!! I seriously appreciate all the help! Thanks so much
$ 16.00
$ 25.99
Lee's Parts
$ 19.00
