When you do your rebuild, mount your resistors high off the board so you will get air flow underneath. Ideally you should use ceramic (or some type of high temp) stand off mounts... unfortunately I did not have any available.
(BTW, this solder repair job looks pretty bad because I was repairing some else's old hack job)
The transistors mounted to the aluminum heatsinks get damn hot, so make sure you use plenty of heatsink compound when you screw down the transistor to heat sink.
The 5W 4.7KJ ceramic resistor at R8 gets the hottest, but I also elevated the ceramic resistors at R11 and R9 as well, it helps keep them away from the heatsinks which should reduce the overall heat in the area.
I also elevated the resistors at R13, R6, R12, R3 as well... they also get hot (interesting note.. in the rebuild kit they upgrade the replacement resistors here from 1/2 watt to 1 watt.)
