(Topic ID: 226822)
Fixing Alkaline damage on WPC-89 first attempt.
By Langless28
6 months ago
  • 36 posts
  • 13 Pinsiders participating
  • Latest reply 11 days ago by Langless28
There have been 19 images uploaded to this topic. (View topic image gallery).
#1 6 months ago
So the mpu has corrosion. Mostly on left side and up to U15 it looks like. Game works 100% no issues with switch matrix or resets.
Being a believer of if it's not broke don't fix it but ALSO understanding this WILL get worst and something will stop working, what should I do?
1. Take it out and follow terry B's damage guide and replace all affected components.
2. Neutralize damage and wait until something breaks and revert to #1.
3. Play game until something goes wrong and revert to #1
#2 6 months ago
You have damage down to J212, I'd get it repaired now if possible.
-3
#3 6 months ago
Change the batteries, clean up the board and leave it for now. If it still works why repair it now??
#4 6 months ago
take it out now and get it repaired properly now by someone who knows what they're doing not someone who thinks splashing some vinegar on it and giving it a hug is all it needs.
#5 6 months ago
Quoted from Spencer:
You can roll the dice but I would get it taken care properly asap. My Congo had bad corrosion. I had the board neutralized and cleaned. I don't think that did much good since the mpu went dead not long after.
#6 6 months ago
Friends don’t let friends use on board batteries.....
#7 6 months ago
I think I'll gather supplies and try to fix it before it gets worse. Getting a twobits board is possible too.
What do you think is easiest, assemble a twobits board from scratch or a repair alkaline damaged wpc board? Is there a market for damaged wpc bosrds?
I have not done this stuff before but am an automation engineer so it's in my realm of knowledge base and pay very good attention to detail.
#8 6 months ago
For the record, its alkaline. Batteries do not leak "acid"
#9 6 months ago
Remove the batteries,, cut off the battery holder, neutralize with zep, remove the affected components, neutralize and sand, repopulate the removed components, and don't use alkaline batteries again (switch to NVRAM, a coin cell, or memory cap).
The alkaline will spread throughout the board and eat up traces if it's not treated.
#10 6 months ago
Quoted from Langless28:
A repair would be easier in this case. The damage damage doesn't look too bad. It is a considerable amount of soldering to assemble a board from scratch and many hours of labor over several days. And that's just if you assemble everything correctly, have perfect solder joints everywhere, no solder bridging, and put all the components in the right places.
Not really. $10-$20 on ebay without the ASIC chip, maybe? Basically peanuts. Battery damaged WPC MPUs are not hard to find. Everybody wants to get rid of them.
#11 6 months ago
Quoted from GLSP3022:
Yes I corrected myself in later posts. Acid just sounds so much cooler.
#12 6 months ago
It sounds like you are capable of doing the work and looking for suggestions; I can only speak for myself, but I would look at this strictly as a factor of time. You are looking at removing and replacing roughly 40 corroded parts, many of these are not going to come out clean due to the corrosion and damage can be expected to some of the thru holes, the alkaline then needs to be neutralized and the board sanded to remove the corrosion and allow for the soldering of new parts, all holes that pass connections to the opposite side of the board need to be tested and repaired.
Personally, I wouldn't make the time commitment to repair the board and would just replace it; however, since all of your questions end with "Take it out and follow terry B's damage guide and replace all affected components." I would recommend doing this sooner rather than later, as the damage is going to just get harder to fix the longer you wait.
Hope this helps.
#13 6 months ago
Quoted from Pin_Guy:
Hope this helps.
Thanks for feedback. The main reason I got into pinball is for the fixing/ tinkering aspect of it. Up till now I've avoided pins with major board issues but I'm looking at this as a forced learning experience. Aka learn enough and do a good job or I'm out $180 for a new mpu.
#14 6 months ago
Worst case scenario, you cant repair it and are out a board...on the upside if you end up having to replace it, the old one will make a good practice board for learning on. With the relatively low cost of this board (without CPU, ROM, ASIC) I doubt you would find anyone that would repair it for less than 80% the cost of a replacement.
If you are cost conscious, have time to do the work and want some soldering practice, an option is to build your own MPU; depending on your skill level and how detail oriented you are, it will take roughly 10 hours to build one. The soldering time is less than an hour of this, most of the time is spent identifying and bending components, cleaning, and inspection. The build cost is just over $100 and the best thing about this is your machine is operational and you can work on this a little at a time until its finished...see this thread for details: https://pinside.com/pinball/forum/topic/twobits-wpc-mpu-complete-assembly
#15 6 months ago
Quoted from ForceFlow:
I think I got $50 out of one on eBay with acid damage and no chips a month or so ago
#16 6 months ago
Cut battery holder off right now!
Then read this before you start anything.
https://pinside.com/pinball/forum/topic/stripping-battery-corrosion-with-a-strong-acid
#17 6 months ago
Well. Entire bom of wpc-89 components on order from mouser, logic probe, and desoldering tools on the way. Not to mention remote mount battery holder.
We shall see how this goes.....
Good news is I have a demo man mpu to verify signals or values if I get into trouble.
Worst case I have a double E at work I could pick his brain if I have too. And all you wonderful people!
#18 6 months ago
If you are replacing the RAM anyway, you should go with NVRAM and never worry about batteries at all.
#19 6 months ago
Quoted from vid1900:
I hope I don't have to replace any upper components or stuff to right of battery holder. Just ordered all components because I'd rather have everything then pay another 7.99 for shipping of 0.1 lb of electronics from mouser.
That being said I am going to expo next week so if there are show specials on nvram, I might pick it up anyway.
#20 6 months ago
Which game is this going in? If there is a midnight madness mode it won’t trigger at the correct time with NVRAM since the machine won’t hold time correctly.
I agree with your fix it approach!
#21 6 months ago
Quoted from metahugh:
It's a party zone so no midnight madness. Yes I remember reading that some games loose functionality with nvram... like TZ.
#22 6 months ago
Funny, your post prompted me to mention the whole timekeeping concept because I just bought a HomePin reproduction CPU board that has NVRAM pre-installed. It's going into my TZ. BTW HomePin does include a little slip of paper with their CPU reproductions reminding you to replace the NVRAM with static RAM.
Have you thought about buying one of those blank CPU boards to populate? I bet that would be fun. I have one myself, just haven't had the time to setup an order with Mouser myself.
#23 6 months ago
I will make this trade for you for free
#24 6 months ago
Yes I posted about new bare board here and on two bits post. Will try to fix this and weight my options if I fail.
4 months later
#25 64 days ago
Because of the absolute success of my two bits build I can now focus on attempting to fix this.
So I first went to neutralize the alkaline with 100% acedic acid. Seemed to help a little. Now using trusty hakko desoldering gun to remove stuff. Adding flux to the solder really helps. Small pile accumulating so far.
I’ll attempt to document this here for anyone who is interested.
9F1658C1-B742-4B37-8637-12B72C6119CA (resized).jpegE60498E0-C895-40A7-A183-B7199742230F (resized).jpeg
#26 61 days ago
Made some more progress. I have what I think is all the affected parts/areas.
0ECF554A-BF94-456E-ADD6-81233A8EE9F9 (resized).jpegB0791E5B-D75E-4FA1-82C5-079A9D0C5A18 (resized).jpeg
These photos are of areas that I don’t think are affected. The stuff around the pins might be flux from old repair work perhaps?
I might take out U14 but U13 & up I can see trace and board repair so I do not want to mess with it at all. The hazy ness on component side is from the ipa flush FYI.
0B0D580A-181E-46A8-B406-1E21A6AB0129 (resized).jpeg528AE960-5F0B-471F-9FDA-61C9DFD2F6BC (resized).jpeg50155456-A75C-4167-A128-3197D69D724E (resized).jpegB3F6DE53-A9B7-488B-B958-154868E74A62 (resized).jpegBA8874FF-B57E-4B4A-84E4-F25915012959 (resized).jpeg
#27 60 days ago
Removed what I think is all the affected parts off the board. Did a second rinse/ soak with a 5% solution of hydrocloric acid. I see some darkening areas concern near the bottom left battery terminal and I will start abrasive treatment next. I only see a few traces that have darkening under the solder mask. All the pads should clean up nicely.
#28 55 days ago
Used a pointed green cratex bit chucked up in my flex shaft and under magnification brought everything down until it was all shiny.
Fixed some vias and had to add solder to remove some stubborn stuff in a few through holes. Looks like it’s accepting solder well. Last thing to do is rinse the board well with ipa and used compressed air to get any little debris out of the through holes. Then I can finally start adding components on again.
8974021F-C24C-4CB8-AA2F-88E87B46B21A (resized).jpegB174CBC0-885F-48A7-B7BF-3D463B56E511 (resized).jpeg
#29 55 days ago
WOW! You did a fantastic job on this board; not only does the board look great, I don't see a single broken trace anywhere which can be extremely difficult to pull off on a corroded board.
#30 55 days ago
Well this board was in fact 100% working even with the damage so I don’t think it was very severe. At least not ground plane eating kill your board in 60s flat type of corrosion. But I know it just takes time so wanted to get rid of it.
#31 49 days ago
Repopulating is going well. Very angry because I thought I ordered enough 1.2k resistors but am 8 short. Plus the Q1 transistor. So now I need to wait until those items come in. I held off on the diodes and some chips because these areas have sanded traces underneath them. So the plan is to clean up the flux. Brush some conformal coating on the areas under chips/components. Then I will finish the board, test and then final clean and brush coating over the reworked section
Solder is taking well to these pads. And yes, definitely use liquid flux to assist the solder. I also used 5 core solder as well and it works great.
3 weeks later
#32 23 days ago
So after getting a DOA processor and replacing it, board boots! All column drives strobe besides Column 8, it stays high. Pin 11 of U20 also stays high. U20 pin 8 is stuck low and so is pin 12 on U14. U14 pin 10 is grounded and pin 20 has 5volts. R74 tester good at 1kohm, good continuity to 5 volts and pin 9,j207. What to check after that?
#33 23 days ago
Check continuity on the D7 data line (red line)
#34 22 days ago
Quoted from zaza:
So tested continuity from all D7 pins back to the asic. All checked good and very low resistance.
Perhaps it’s because T2 doesn’t use column 8 and that’s the rom I have in?
#35 22 days ago
That is very well possible.
When menu switch "ENTER" behind the coindoor works, it confirms that D7 signal is just fine.
#36 11 days ago
Quoted from zaza:
Happy to report that it was the T2 rom that was disabling the 8th switch column, its not needed for the game. swapped out with a PZ rom and it works great.
So this was a successful repair!
$ 129.00
LED OCD
Gweem's Mods
Killeen, TX
$ 9.99
Yorktown Parts and Equip
