I'm having a very intermittent and odd issue regarding the ball when it enters the jukebox.
For the most part, the machine sees the ball and releases it. Sometimes it's a hard kick and sometimes it barely pushes it out.
Using a pinball, the machine reads the switch open and closed in switch test, and the coil is strong in coil test. I've never seen a problem where this coil doesn't angrily launch the ball out when using the skill shot.
Last night, the ball just stayed in the coil. Machine goes through ball search and nothing. Staring at the ball to see what it's doing or not doing makes me notice the coil is firing but only enough to move the ball, but not pulse hard enough to remove the ball.
I've reseated switch connectors and coil connectors to the jukebox. The problem seemed to go away, but I'm convinced it will return. I've read others having this issue too, but didn't really find a solution.
I've also noticed when the jukebox is lit for song change, that if you shoot it, it sometimes doesn't activate this feature but still releases the ball. So if it's switch related, the machine knows it's there to release the ball but it doesn't know it's there to activate song change? This is the weird intermittent part.
Thanks in advance.
p.s.
The double cannon fix has held up well and works like a charm.
http://pinside.com/pinball/forum/topic/acdc-two-ball-cannon-ramp-fix
