(Topic ID: 84928)
ACDC Ramp Mod - Railroad
By Geremy13
10 years ago
  • 9 posts
  • 5 Pinsiders participating
  • Latest reply 9 years ago by JDD
#1 10 years ago
Wheww..! Just got finished. OK, so I installed the Railroad Tracks Train ramp mod decal on our ACDC. Picked up a set of ramp mods from pinballlife.com. I saw this mod in person at the Louisville Pinball Expo... and I have to say that the pictures didn't convince me to make this purchase. But seeing it in person I knew I had to have it!
I have read many posts on folks that have done it, some doing it wrong, (installing on the top of the ramp), lots of pics showing the finished product, but not much comment on the installation itself.
So I will proceed to comment. IT'S A JOB!... Sure it's a 'sticker', how hard can that be?... So I went in with that mindset and proceeded to think this is a 15 minute job. Now here's the problem. I am a perfectionist. It must be perfect. So I begin to tackle the job. (1st comment there is no instructions so you just need to figure it out.) No possible way to install this 'sticker' underneath the ramp unless your hands and fingers and the rest of you is the size of a midget Barbi doll. So you have to remove the ramp... (I just finished the Eli mod on the Tron and removed both ramps... NOTE: It was more than a sticker so I planned it to be an all day job... AND IT WAS!...... AND it was worth it!)...
But this is just a decal so what am I getting myself into?.... Well, first I had to remove Brian Johnson... I have him mounted on the left ramp so he has to go, then 6 connections underneath the playfield that light up various parts that are connected to the ramp. None seemed to be properly marked with the 'colored' pen and so documenting all wire colors and expected locations was necessary for successful re-assembly. Then remove any fasteners that hold this ramp down, NOTE: I did not remove any lighting or switches from the ramp if I didn't have to as I was going to be careful installing this decal and not intending to affect any other attachments. Remove the 2 wood screws that hold the bottom of the ramp to the playfield, then tilt aprox. 15 degrees to the right to detach the 'crossover' ramp on the premium model, then tilt simultaneously about 22 degrees toward the front of the machine to attempt to 'clear' the LED's that are mounted on the back panel. This should now allow you to carefully remove the left ramp assembly for installation of this most wonderful sticker. Once removed place upside down on a carefully woven piece of indian knitted afghan and locate on a solid oak coffee table somewhere near a TV so that you can take a breath and relax a bit. If there is a refrigerator nearby that contains the remaining beers of your 12 pack, that will make it easier. (if there are any beers left.)
Now comes the hard part: Install that sticker! (approx. 90 seconds if you're careful and take your time.)
Re-assemble all that you have done above and you're done!
End result is very nice! Would I do it again?... YES!... but I would've purchased more beverages for the duration of this project. All in all I am very pleased with the way this looks and it looks just as I expected... VERY NICE... seeing it in person is much better than the pictures that I've seen.
Will I complete the second part of this project (the Cannon balls on the right ramp)?.... NO!
NOTE: Canon ball modification for ACDC Pinball machine for sale. $15 shipped! PM me and I will ship right out!
#2 10 years ago
I love the clarity of the acdc ramps. They're clearer than most ramps. I wouldn't want anything to limit this
#3 10 years ago
Glad you like them. I still have some available but do not plan to rerun them again.
Terry bought a bunch from me and should have them in stock for a while.
The only way to do it right is to take the ramps off an spend an hour (for both).....just turn on your acdc Juke and enjoy your time.
Hope to run some of the same type ramp decals for other machines in the future.
Another location that is easier to install would be between the cannon and the flame plastic on the underside of the ramp. Just trim around the decal with sharp scissors or a blade.
#4 10 years ago
Quoted from HOOKED:
Excellent Idea!....... Thank you so much. This is exactly what I will do... I just checked out the clearance in this area and I can see that it could be done without removing the ramp....
I am curious, since this decal is/ has adhesive, have you ever tried or suggested Windex or some other liquid to smooth out the bubbles. (micro bubbles but still)... any suggestion that you have is appreciated. Of course since it is adhesive it may not be considered anyway. I don't know.
Canon Mod for right ramp for sale: WITHDRAWN. (I'm gonna keep 'em now).
#5 10 years ago
I believe I posted tips on the original post but ...
I clean the ramp underside just to clear dust off if any.
After cleaning I peal back and cut off the first inch of the end of the decal so I can line it up from ramp entrance to end.
Using a plastic squeegee or even a credit card edge, I work from the end back to the ramp entrance pealing back the paper backing as I go.
The decals are resilient and I have started over one time without issue.
#6 10 years ago
Quoted from HOOKED:
Thank you HOOKED... Yes, I have read the post and recommendations. They are good suggestions. I just am difficult when it comes to Perfection and so I was working on a way to make any micro-bubbles invisible. Of course they're not visible without a high powered flashlight, but somehow in my brain, I know they are there.
I appreciate all of your help and your excellent product. I am the guy that would laser cut out the actual canon ball to install each one individually .... WOW,, in fact, I just game me an excellent idea!... (I know a little nuts...)
#7 10 years ago
Lol I held the sticker like a pizza slice, loosened the flap at the bottom of the ramp and shoved it up. Have maybe one crease if you look close . Took 3 minutes.
#8 10 years ago
Quoted from DCfoodfreak:
Now that's funny right there!...... Seriously!.... I know all this LMAOL ONTHEFLOOR... abbreviated stuff and what not.....
But that right there had me on the floor laughing un-controllably ..... my wife walked in and was wondering what happened....?
And so, I quietly shut up, got up off the floor, and went back about doing my business, ... and finished washing the dishes...
6 months later
#9 9 years ago
I just purchased an ac/dc premium and I always try to avoid mods, but the train track sticker was just toooo perfect. The flaming cannon balls, however, didn't really appeal to me.
Then I came up with some alternative placements.
1) farther up the highway to hell ramp, just past the switch
2) right before the cannon
I think the balls look fine in that location.
FYI
JD
cannon ball lg-104.jpgcannon ball lg-104.jpg cannon ball sm.jpgcannon ball sm.jpg
$ 17.50
YouBentMyWookie
$ 99.99
$ 11.95
Game Room Info Shop
Filament Printing
$ 14.95
$ 29.95
$ 110.00
$ 11.95
$ 160.00
Sparky Pinball
$ 50.00
AC/DC Glass Cover Pre-order!
Duke Pinball
$ 159.00
Sparky Pinball
$ 100.00
Duke Pinball
5,600 (OBO)
Chittenango, NY
$ 12.95
€ 99.00
Lighting - Under Cabinet
Watssapen shop
Hookedonpinball.com
$ 29.95
6,900
Sadsburyville, PA
12,000
Ontario, CA
16,500 (Firm)
$ 29.95
$ 99.99
PinballGeek
This page was printed from https://pinside.com/pinball/forum/topic/acdc-ramp-mod-railroad and we tried optimising it for printing. Some page elements may have been deliberately hidden.
