Quoted from Spyderturbo007:Do you mean the AC/DC stand ups? If so, there isn’t any wear at all. I haven’t found any wear other the shooter lane. I’ll know more when I tear it down though.[quoted image]
Thanks, some reassurance that playfield can handle the cannon.
Quoted from pinballjah:Thanks, some reassurance that playfield can handle the cannon.
I wouldn’t make that assumption about the play fields they are pumping out today.
My BM’66 is falling apart.
Quoted from Spyderturbo007:As requested. 18,488 paid credits with a 19% match and whatever else was earned through free games. Definitely more than 22,000+ games on this bad boy.[quoted image][quoted image][quoted image][quoted image][quoted image][quoted image]
Yeah but are there dimples!!?? Lol
Congrats on the machine. Some of the nice LED lightning bolts out there for sale now will fix those broken ones right up. I love mine. And Cliffy protect that shooter lane and it’ll help that out. Impressed that the ramp plastic look nice, but a shame about the cracked entrances. I’ve seen that a ton on the machines that didn’t come with the metal edge armor on those ramps like the vault editions do.
Quoted from ezatnova:Yeah but are there dimples!!?? Lol
His appears to have the metal edge armor on the ramps. Right?
Had to zoom on to spot that one. They actually don't have the metal armor. Good observation.
I think the entire play field is one giant dimple. Dimples don't bother me as much as chunks of paint falling off the play field.
Quoted from ezatnova:I’ve seen that a ton on the machines that didn’t come with the metal edge armor on those ramps like the vault editions do.
I'm trying to find out if I can buy them, but not having much luck. I emailed Cliffy to see if he makes them and might not have had time to put them on his website.
Anyone have a new plastic set they want to sell for an original pro?
I ordered on from PBL, but they just found out that it's back ordered with Stern.
Quoted from Spyderturbo007:I think the entire play field is one giant dimple. Dimples don't bother me as much as chunks of paint falling off the play field.
I assume new ramps (with the protectors) are prohibitively expensive?
Not saying it would be easy, but you could try to get some lengths of aluminum or stainless from Home Depot and bend them into a U of the correct width to maybe superglue them into the ramp side ends. Riveting would be better but obviously way harder.
Quoted from ezatnova:I assume new ramps (with the protectors) are prohibitively expensive?
I ordered ramps from Marco and they don't have the protectors. They came scuffed up, which I'm still pissed about, but that's a side note.
Cliff got back to me and said he doesn't make them for the Pro. Guess I'm going unprotected.
Quoted from Spyderturbo007:I ordered ramps from Marco and they don't have the protectors. They came scuffed up, which I'm still pissed about, but that's a side note.
Are the ramps different on the different versions???
Quoted from Boondocker:The Pro's did not come with the protectors. I added these when I replaced my ramp.
https://www.marcospecialties.com/pinball-parts/535-0579-01
I’m assuming you had to drill out the new ramps? Mine didn’t come with holes for screws.
What screws did you use?
They must only come with the vault / pro edition.
Mine did. It’s a vault, but regardless, obviously the part exists.
Quoted from Darscot:I have an original pro and it has the protectors.
Mine to, on both ramps both sides but it is an LED version w the bell installed.
Quoted from Spyderturbo007:I’m assuming you had to drill out the new ramps? Mine didn’t come with holes for screws.
The new ramp came with holes (and an extra bumpout area for the screws - second picture). Had to drill hole in old ramp on one side. Added a nut to the back of the screw on the other side where it didn't have the little bumpout and the hole in the protector was off the plastic.
Came with screws.
I think I had a later model Pro as it had the stupid spring added on the top of the playfield.
Thanks for the pictures. I'll have to look at my ramps a little closer when I get home. I know they don't have screw holes, but I think they have the little bump outs.
Hey everyone, what are your typical scores?
I hit 40m pretty often, but also get pretty frustrated like,
"oh come on I've had this machine for over a year and I still can't hit that right ramp shot reliably?"
what are some of your thoughts about your play or scoring?
Mike
Quoted from pinbuoy:Hey everyone, what are your typical scores?
Mike
Unless I play this game consistently I am unable to hit the left/right ramps for multiple combos.
I have a bunch of games, so whenever I get around to AC/DC, it’s like I’m playing it for the first time (which means I can’t hit shit). I’ll start to dial it in after about 5 games.
My back ordered plastics should be here tonight so I can start my tear down. I have to figure out what I'm going to do with the scuffed up new ramps I got from Marco though....
Quoted from Spyderturbo007:My back ordered plastics should be here tonight so I can start my tear down. I have to figure out what I'm going to do with the scuffed up new ramps I got from Marco though....
Post some pics
Quoted from pinballjah:Ordered by mistake and does not fit Pro LED version swinging bell. Cut the back side off and added a little two sided velcro. Think it looks pretty good.[quoted image][quoted image]
Indeed it does, pinballjah - where did you order this mod from? Thanks.
Quoted from EightBitWhit:Indeed it does, pinballjah - where did you order this mod from? Thanks.
It was from Pinball Life
Quoted from newpinbin:Post some pics
I'm not too thrilled with these. I'm afraid to send them back, because I'll probably get something worse.
Quoted from Spyderturbo007:I'm not too thrilled with these. I'm afraid to send them back, because I'll probably get something worse.
Are those used?
Where were they ordered from?
Quoted from newpinbin:Are those used?
Unfortunately not. Brand new.
Quoted from dmacy:That sucks. Any way you can get a decal to put over ac/dc related?
I think someone sells train track stickers for them...
Quoted from newpinbin:Where were they ordered from?
Marco.
Quoted from Spyderturbo007:Unfortunately not. Brand new.
Marco.
You should call them. The first pic looks like its cracked.
I came across this video. I thought it was very ingenious!
https://www.cnn.com/2020/01/25/us/thunderstruck-video-baby-acdc-trnd/index.html
Quoted from pinbuoy:Well the time has come. ;-( My first brand new game in my life and I'm trading it. Almost lost a lil sleep over it last night, but I'm bored w it, so its time to go. Theres nothing like getting your first NIB pin...
I think that’s why I’ll never let mine go. Aside from the awesome tunes and always fun gameplay, it was my first NiB that I saved up for and wanted badly for a while until I could pull the trigger (pulled it...pulled it...pulled it.......shoot to thrill!)
No way! I always come back to this machine, keep it. I could never find a pro for a decent price. Then the vault edition came out, which went for less than a used one at the time. Scooped one up and never looked back.
Quoted from newpinbin:No way! I always come back to this machine, keep it. I could never find a pro for a decent price. Then the vault edition came out, which went for less than a used one at the time. Scooped one up and never looked back.
I could keep it but I'd be bored. It's just me and the nature of having 1 game. I love WCS and TZ and eventually w just one I'd get bored w anything. We bought it because my wife fell in love w it, but now I'm the only one that plays it. Might as well get something different.
This will eventually happen to every game you ever own. When you get a game, it has a hidden number of games that you can play on it. And as you play it, you get one game closer to hitting that point where you are playing it, and feel restless and bored as you shoot it. For great games, that number can be in the thousands. And then it's over, the game has to go. I recognize it in every game I've sold. They all hit that point. And it is just part of the hobby.
So don't lose sleep over it. Because it is usually followed by the thrill of a new game, and then the counter restarts. Even if it was your first NIB, there will be another game to love.
Out of curiosity - has anyone installed a Premium train in their Pro?
If so, are there any additional parts required over/above the train itself? I've looked in the current Premium manual and I'm not seeing any reference to anything other than the actual "Molded Train Toy - 511-6987-00", but when I look on the bottom of my train vs. the Pro playfield there's not a good way to mount it using what is available.
Am I missing a mounting plate or something else that secures the train to the left ramp?
TIA for help on what I know is now an "old mod".
Sad but amusing story. So i never quite liked the vault bell mech compared to how i remember it on the premium. Today, i just happened to take a look at it and found out why. The bell was resting on the left part of the metal guide causing it to bind up a bit. It made for tough and unsatisfying bell hits. Well, loosened the two screws holding the bracket, repositioned and tightened. Bell swings super freely now how it should. So good to hit, so satisfying.
Long story short, check your bell guides to make sure it’s not binding.
Quoted from EightBitWhit:Out of curiosity - has anyone installed a Premium train in their Pro?
Mine came with the after market train. Seems to work ok. I used two way Velcro to secure it.
Yep. One of the best mods. Two way Velcro and soldered on alligator clips. Clip it to the RnR Train song jukebox leads
Quoted from ezatnova:Yep. One of the best mods. Two way Velcro and soldered on alligator clips. Clip it to the RnR Train song jukebox leads
Fantastic - thank you @ezatnova - I'll work towards those items.
Quoted from Eskaybee:Sad but amusing story. So i never quite liked the vault bell mech compared to how i remember it on the premium. Today, i just happened to take a look at it and found out why. The bell was resting on the left part of the metal guide causing it to bind up a bit. It made for tough and unsatisfying bell hits. Well, loosened the two screws holding the bracket, repositioned and tightened. Bell swings super freely now how it should. So good to hit, so satisfying.
Good point. I've recently installed the Vault bell mech on my "first run" Pro machine. Personally, I like the Premium bell mech better, as it is suspended overhead, secured at the left side, and there is no metal guide to limit the swinging action of the pendulum. I'm wondering why Stern put that guide on the Vault, as there's really no way for the pendulum and/or bell to "move" from side/side regardless of whether the Vault or the Premium mech in use. Seeing how the Vault guide *could* move over time, it seems like more a liability than anything else.
The Premium mech "looks better" (IMHO) since there is no guide.
Quoted from EightBitWhit:Good point. I've recently installed the Vault bell mech on my "first run" machine. Personally, I like the Premium bell mech better, as it is suspended overhead, from the left side, and there is no metal guide to limit the swinging action. I'm wondering why Stern put that guide on the Vault, as there's really no way for the bell to "move" from side/side regardless of either the Vault or the Premium mech in use. The Premium mech "looks better" (IMHO) since there is no guide.
Did you buy it as parts individually? I saw a thread on that here but it seemed rather pricey to buy that way? I just have the swinging bell mod on my original run pro and I'm pretty happy with it but maybe its time to upgrade.
Also on the topic of the train mod is there any good mod to for those that replace that song with Dirty Deeds?
Quoted from EightBitWhit:Fantastic - thank you @ezatnova - I'll work towards those items.
I forgot the last thing...frosted led (I highly prefer red to go with the theme). The cool/ice and blinding clearness of the stock bulb was not ideal.
6E703549-EEA4-4497-92A4-0781CEF834ED (resized).jpeg8FDC26C7-D6E6-430D-9506-E40D5096BE70 (resized).jpegQuoted from Darscot:Did you buy it as parts individually? I saw a thread on that here but it seemed rather pricey to buy that way? I just have the swinging bell mod on my original run pro and I'm pretty happy with it but maybe its time to upgrade.
Invest $20 in Pinball Browser and make all the changes you want.
https://pinside.com/pinball/forum/topic/acdc-display-and-modify-dot-matrix-images
This page was printed from https://pinside.com/pinball/forum/topic/acdc-pro-club-stand-up-and-be-counted-only-500-made/page/9 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
