Greetings! I have been having an issue where the ball gets stuck behind the Hell's Bells. The ball search will eventually release it but it does hold up gameplay. Any advice?
If the bell is not swinging freely you may need to tighten the ball. Over time it starts to unscrew and will hit the playfield. If it's getting stuck in the saucer behind the bell, I'd check the saucer switch.
Quoted from TomGWI:Sounds like the switch in the hole either needs to be adjusted or replaced.
Think you right bro. The ball does not "eject out" with a lot of authority. Kind of just rolls out and hits the Hells Bells Ball and just sits there.
Quoted from SunKing:If the bell is not swinging freely you may need to tighten the ball. Over time it starts to unscrew and will hit the playfield. If it's getting stuck in the saucer behind the bell, I'd check the saucer switch.
Will check that as well...thank you.
The bell on my machine hits the glass when hit hard enough. I may need to check to see if it needs to be tightened.
Quoted from wiggy07:The bell on my machine hits the glass when hit hard enough. I may need to check to see if it needs to be tightened.
Had same problem. used lock tite on bell threads as they kept coming loose. Holding so far.
This is not a problem. It is cool
This page was printed from https://pinside.com/pinball/forum/topic/acdc-premium-issue-1 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
