(Topic ID: 86651)
AC/DC Premium/LE club
By MMforever
  • 1,691 posts
  • 259 Pinsiders participating
  • Latest reply 2 days ago by Dent00
  • Topic is favorited by 131 Pinsiders
There have been 353 images uploaded to this topic. (View topic image gallery).
2 key posts have been marked in this topic (Show topic index)
There are 1691 posts in this topic. You are on page 22 of 34.
#1051 12 months ago
Quoted from xsonics2k2:
I'm getting a ball hangup on the top right rollover, the rubbers are wide and if the ball rests in the playfield cutout for the switch, it will just sit there. I've seen others post about this... maybe a cliffy lane switch will fix it?
Can you post a pic of exactly where this is? If it's where I'm thinking it is, changing that 7/16 OD rubber with a 3/D rubber will fix the problem. Friend of mine (luci as well) had a tight clearance their and that rubber was actually holding the ball in the lane on slow moving balls.
If it's hanging up with just clearcoat their then a cliffy wont fix that.
#1052 12 months ago
I've got a question for everyone though. Anyone elses bell swing too much? I've noticed recently that after a solid bell hit my bell will keep swinging for more than 20 seconds. I know this timeline is correct because I constantly lose my 2x scoring because the bell doesn't stop swinging in enough time to keep building it or restart the timer. Really frustrating now. I don't think there was a code change their but it would be nice if after a couple seconds the magnet would stop the bell.
#1053 12 months ago
Quoted from 85vett:
That's normal, but agree that a short magnet stoppage action would help.
#1054 12 months ago
Can someone with an original AC/DC run take a pic of the inside of the backbox panel where the stock DMD mounts? I'm trying to figure out what parts I need to order to swap out my ColorDMD back to a regular DMD. I'm not sure if I need the plastic shield or not since it's a LED display but the ACDC manual shows it.
#1055 12 months ago
here is a longer video
#1056 11 months ago
fyi, I am making a LIMITED run of 10 with the spare material I have. PM if interested.
Please read the pinside AD.
https://pinside.com/pinball/forum/topic/acdc-roof-band-mod-lighted
#1057 11 months ago
Quoted from flashburn:
Not really sure if this helps; is there a specific angle maybe? Just Lemmy know man.
#1058 11 months ago
Quoted from Gryszzz:
Thanks a lot! I couldn't find the plastic shield anywhere, but I have the paper one from another display I pulled out of GoT, so I suppose that will do. I think the plastic shield is a holdover from when they were doing Plasma displays.
#1059 11 months ago
Just got my Luci a few days ago, and installed a shaker but it's not working. Everything thing seems to be plugged in correctly. In the settings the shaker motor was set to Maximum use. I tried a coil test on the motor and it didn't go on. How do I troubleshoot this? Just bought the shaker, but not sure thats the issue or not.
#1060 11 months ago
Are both cables plugged in?
One cable goes from the shaker to the pcb board.
The other goes from the board to the back of the cabinet ... on the bottom is a brown wire with a molex connector. Is that plugged into the cable going to the pcb board?
#1061 11 months ago
Quoted from Guzz4851:
Yeah, unfortunately.
I'm looking at this post and seeing if this is the issue.
https://pinside.com/pinball/forum/topic/shaker-motor-install-in-recent-stern-acdc
Edit - this wire says "shaker motor ground." There is No where to plug it though. Did i get the wrong part?
#1062 11 months ago
Just wondering for those that have the Pinbits illuminated lightning bolts if anyone has preference for the standard white vs. red. vs. blue filters and how they look in actual gameplay on the playfield (I've watched the Youtube video but hard to see how it lights up the playfield with the color variations).
Any opinions from those that have installed these?
#1063 11 months ago
Quoted from DrMark12PA:
I have them. Most people seem to like the red, but I think the red is just too much red added to already red heavy lighting on the playfield and doesn't contrast more with the rest of the game lighting. To me those flashers should be a pop of a different color. I chose blue and it is kind of a washed out blue like a real life lightening bolt - not a dark rich blue. It goes very well with the white back flash, like a real lightening flash. The red with the white back flash ... just doesn't seem like the right combo to me for a lightening bolt. The front flash isn't super bright to flash the bulbs directly in your eyes. The back flash is awesome. Just my opinion ... I like them better than the others that are on the market.
#1064 11 months ago
Is this a normal ball hang up spot?
If so, any fixes?
#1065 11 months ago
^^^^I've had that happen to me...maybe 4-5 times in the few thousands of games that have been put on the machine. Wasn't frequent enough to worry about. I would have to wiggle the machine a bit...and sometimes tilt that ball.
#1066 11 months ago
Looking for this mod. Any help would be appreciated.
#1067 11 months ago
I've tried pretty much every combination.
The straight white bolts were just way too blinding. I tried the blue bolts and filters, but they seemed to clash with the warm white LEDs on the bolts. Ultimately I felt that the red bolts and filters blended the best with the game without being blinding. Obviously, YMMV.
#1068 11 months ago
I went with white and have been really happy with them. Yes, they are very bright!
Quoted from Shapeshifter:
If so, any fixes?
I wouldn't say it's common but does happen occasionally. I can usually get mine to come loose with a light nude during the ball search.
Quoted from jester523:
Their should be a long single brown wire in the bottom of the cab (around the transformer). It's going to be hidden in that mess of wires down there. it's the only single brown wire in the lower part of the cab so you will know you have the right one. I think it should be an IDC connector though.
Found a video of someone installing their shaker in a MET. Will be the same for AC/DC.
#1069 11 months ago
I went with the white pinbits bolts. In my opinion, the original bolts were meant to mimic concert flashers, which are quite bright. I think the white ones do a great job.
#1070 11 months ago
Quoted from 85vett:
Found a video of someone installing their shaker in a MET. Will be the same for AC/DC. » YouTube video
I should probably update on this. This drove me crazy for 2 days. Everything was plugged in correctly and it didn't work. I contacted pinball life and Scott Danesi was helping me trouble shoot. He asked me to check the fuses and they were fine, but when I put them back in it started worked. I guess they werent seated properly? Not sure, but it's working now. Felt kind of stupid for not checking the fuses. I just assumed they would be fine straight out of the box. Shaker is working great now.
#1071 11 months ago
Don't feel to bad. I spent 30 mins trouble shooting a shaker install on a game I bought used. Fix was simple, just had to turn it on in the settings. Previous owner turned it off since it didn't have one and it took me 30 mins to even check that.
#1072 11 months ago
Quoted from 85vett:
Sorry for the delay, here it is. Yep, I need to put a different rubber in there. Thanks!
#1073 11 months ago
My War Machine spinner is barely recognizing a solid shot up the left lane.
I noticed the metal spinning arm is resting on a screw that holds the bumper (to the right) in place. (See picture)
The metal arm that holds the spinner has a flat wear spot that causes the target to rest at an angle instead of straight up and down. (See picture) The ball will typically go right under without touching the target, sometimes it will brick off the front.
I have been messing around with adjustments and can't seem to find one that works. I tried loosening the screw and moving the bumper to the right, but it didn't help. I'm tempted to cut a few milimeters off the arm so it doesn't touch the screw.
I'm hoping someone can point me in the right direction here.
Thanks,
Brad
#1074 11 months ago
The metal arm that holds the spinner has a flat wear spot that causes the target to rest at an angle instead of straight up and down. (See picture) The ball will typically go right under without touching the target, sometimes it willand moving the bumper to the right, but it didn't help. I'm tempted to cut a few milimeters off the arm .....
Can you switch to a flat head bolt - lower profile bolt?
#1075 11 months ago
Look for J3 on the board,it a 2 prong plug in and you can find the plug in as its in the same area, with a label that says shaker ground
You will have 3 wires that should be hooked up ,
1 Brown with a blue stripe
1 red with a white stripe
And the 2 prong wire that’s black and I think it has a yellow stripe
#1076 11 months ago
This is probably the best solution I think. Although 1mm is probably plenty
Rob
#1077 11 months ago
A follow up note about the sticking band member coil on my Luci. I put a small piece of mylar on the coil stop and that seems to have fixed the issue. The coil stop was getting magnetized and holding the coil shaft in.
Rob
#1078 11 months ago
I am making a 4th LIMITED run of 10 with the spare material I have. PM if interested. ACDC Lighted Band Mod.
#1079 11 months ago
Thanks,
Brad
Does it spin fine but not register or is it not spinning well at all?
If spinning well but not registering hits as it should:
I think the reason for this is because the switch isn't very sensitive. Looking at your top pic I can see clear daylight between the switch and the spinner arm. They should be resting on each other ever so slightly. That arm doesn't move very much distance so it needs to be making a solid connection when the spinner is upside-down. As yours sits now on a good hit to the spinner I'm betting it's just not registering well.
If it's not spinning well then that screw could be the issue but in the pic it looks like their is plenty of clearance in the spinner itself even while resting on the screw. I can see where it can move up in the mount so it doesn't look like their is any binding there.
#1080 11 months ago
Shoot, I had that location confused with another location. That orientation looks correct. By the looks of it their is clearance for the ball as well so it shouldn't be holding up their. Is the game at 6.5 degrees pitch or more? If not, I would adjust to at min 6.5 (Stern's recommended pitch) and see if it still continues. If so you could switch to one size smaller rubber their (the long one) for which the extra stretch will give more clearance. Last option would be some mylar around the switch. I don't think a cliffy will work as if the ball is already moving slow enough to be caught like this I feel it would get caught on the upper side of the switch cliffy.
#1081 11 months ago
Had exact same issue on my NIB Luci VE. I removed the screw, and the spinner worked like it should. Noticed the arm was a little bent the last 3-4 mm. Causing it hit the screw. and making the spinner rest in an almost horizontal position.
I managed to straighten the arm using pliers. Now it's working like it should.
#1082 11 months ago
We are upgrading to color DMD, recommend LCD or LED?
#1083 11 months ago
Smoothing works great on this title, so go LCD
#1084 11 months ago
Quoted from Bearcat:
LCD, for sure. LED only when space dictates it.
#1085 11 months ago
I'm having issues with my AC/DC luci vault where the left and right ramps will only work intermittently. Basically if I shoot it up the left ramp and it's not working the diverter will not activate (if applicable) and it will not register as a completed task (e.g. doesn't add to jam multiple, doesn't turn off note, does score, etc). On the right ramp, it has similar issues (does not diver to cannon when applicable). This happens intermittently, and sometimes it works as it's supposed to. I tested the switches and both the entrance and exit switches on both ramps seem to be working correctly. Anyone have issues like this? not really sure what else to check.
#1086 11 months ago
How did you test the switches?
#1087 11 months ago
Quoted from Lermods:
I pulled the glass and put it into switch test mode and threw a ball up the ramp, and I watched to see which switches were triggered. Both the entrance and exit switches are being triggered. I noticed that the entrance trigger is being triggered multiple times on the right ramp as it's swinging back and forth. So it may do something like, entrance, exit, entrance, inlane.
I threw the ball up about 25 to 30 times and it's triggered the exit 95%+ of the time. When I play the ramp works 50% maybe. It's tough to say without knowing how it's programmed, but I assume the lane diverter and completion of the note is triggered by the exit switch. I'm not sure exactly what's happening when I play a game, is the switch not registering or some other issue.
#1088 11 months ago
Did you test the diverters? It likely has to be either the switches not registering properly or the diverters not working properly. Odd that both sides are having issues.
#1089 11 months ago
The diverters are working fine. I tested in the coil test. Plus sometimes it doesn't register that a ramp was scored, so it can't just be the diverter. hmmm...doesn't seem to make sense that the switches would work well when i'm throwing the ball up, and not work when i'm in an actual game. i'll play around with it more but it seems like something is off.
#1090 11 months ago
Quoted from Eldritch:
Thanks for all of the responses everyone! Sorry for the delay, I just returned home after being out of town for a few weeks.
Today I swapped with a flat screw and it didn't help.
Bending the arm was my next step... so I checked this thread and saw all the replies, including this one. I'll give it a shot!
#1091 11 months ago
As info, there is a gap with the Color LCD, I'm not sure if this has been addressed yet. Search through some threads on this just in case.
I'm a fan of LED, I like how vibrant the dots are and I'm more of a purist with the dots vs. blended or XL. The LED is a better fit too, and I do not believe there is a gap with the LED, but I'm not positive.
#1092 11 months ago
The LED does fit better, but the LCD is more versatile. I'm working on a gasket for the LCD that fills up that gap completely so there's no light bleed on the sides. On the jillionth prototype, but we're very close.
#1093 11 months ago
Fixed! Needlenose pliers on the left side of the arm while twisting the spinner and it is straight again. I'll have to keep an eye on this since it bent during 100 plays.
Time for some War Machine!
Brad
#1094 10 months ago
Does anyone know what this space is used for on my VE Pinball. See blue circle in backbox. It has 4 posts.
#1095 10 months ago
Must be a placeholder for something in other games with the metal backbox.
Here is my original and nothing is there:
#1096 10 months ago
Quoted from shovelhed:
Did you find a source for the stick dynamite mod?
#1097 10 months ago
Quoted from cpr9999:
I have not but i look each day.
Harley D.
#1098 10 months ago
Harley D.
Do you know who made the original ones?
#1099 10 months ago
beatmaster made one version of them long ago with wires going to the detonator. I got one about a year or so ago from him that he still had laying around. Maybe check with him. With new ACDC pins being made, maybe he would start those back up if there was enough interest. Doesn't hurt to ask.
#1100 10 months ago
Heard back from beatmaster, he said if there is enough interest he would consider doing another run of the TnT Mod. So im pluging his mod as I think this is one of the coolest acdc mods out there.
7,299 (OBO)
Emerald Hills, CA
$ 90.00
Lighting - Under Cabinet
$ 9.95
$ 24.95
6,100 (OBO)
Rochester, NY
$ 99.99
€ 25.00
YOYOKOPTER MODS
Great American Pinball
$ 48.00
$ 16.50
$ 24.95
$ 48.00
$ 45.00
$ 89.95
$ 38.00
Gweem's Mods
$ 11.95
$ 48.00
